HOW CAN I MAKE MORE POWER?
Alright so i finally finished up my built...motor ended up making 216.78WHP. Im happy with it..but i was wondering if there is anything else i could do to make it gain more power. NOTHING INTERNAL..as far as we would go is maybe chaging the cams..but no pistons or anything like that. here is the specs of the motor build.
Engine:
B20 Block
Bored to 85mm, Honed, Decked,Hot tanked
RS 85mm 11:8 Compression Pistons
B20 Eagle Rods
B20 Crank Microplish and Balanced
ARP Rod Bolts
ARP Main Bolts
ARP Head Studs
Calico Bearing set
Golden Eagle headgaste 85mm
Golden Eagle Dial pins
B20 Moroso Oil pan
OEM Acura Type r Oil pump
OEM Acura Type r Water pump
OEM Acura GSR Timing belt
Golden Eagle B20V oil line kit
GSR Head
Hot tanked, Bronze valve guides, New valve seals, Cleaned, Decked
Skunk2 Springs and Retainers
Skunk2 Stage 3 Tuner cams
Skunk2 Cam gears
Skunk2 pro series intake manifold
Skunk2 70mm Throttle body
RC 310 Injectors
AEM fuel rail
Aeromotive Fuel pressure regulator
3" Intake with Velocity Stack
Hy-tech Tri-Y Header heat wrapped
Walbro 255 fuel pump
Mishimoto radiator
samco hoses
AVID Solid Motor mounts
Brand New Fuel Filter
2.5 straight piping
Vibrant 2.5 Exhaust
All Star Catch can setup
01 Type R LSD Tranny
ACT Stage 4 6puck Clutch
ACT 10lb flywheel
The motor compression was said to be around 12:0 to 12:1 compression. I was looking to maybe changing the Skunk2 PRO to Edelbrock Performance X manifold. Also wat other cams out there can i run on the street that will outperforme the skunk2 stage 3 tuners. Remember i have Tuners series valve train, so i guess that leaves PRO series cams out.
Engine:
B20 Block
B20 Eagle Rods
ARP Rod Bolts
ARP Main Bolts
ARP Head Studs
Calico Bearing set
B20 Moroso Oil pan
GSR Head
Skunk2 Cam gears
RC 310 Injectors
AEM fuel rail
Mishimoto radiator
samco hoses
2.5 straight piping
Vibrant 2.5 Exhaust
ACT 10lb flywheel
Do the IM change to the Performer X. When you’re changing the IM get new injectors FIC525's. They have an improved spray pattern that improves atomization. This equals more power. Is the 3” intake piping a CAI? If not you may want to change that as well.
If you change the IM would you be selling your old one? I am running a Performer X now and would like to conduct a test on my engine with a Skunk2 Pro.
ya im thinkin about changing the IM....wat cams would you suggest i should try? im looking for atleast 225-230whp im at 216whp right now. i can upgrade the IM to Performance X, Upgrade the cams to something better then stage 3 tuners, and upgrade my short ram intake to a CAI with the Velocity stack in the front of the car.
what do you guys think power gains would be?
I didnt really built this motor to be a race car or be the fastest....only reason why im asking what i would do to improve my HP (my goal would be 230whp) is because i know the car has potential. Ive seen 82mm GSR motor do 230...so why cant i make 230 on a 85mm b20? thats where im getting at...
JayDeeEmm
13
Jun 27, 2008 01:01 PM
Honda_Fanatic
23
Nov 9, 2007 07:54 AM
