Removing LCAs from an ITR
Old Sep 14, 2002 | 02:08 PM
Rob :190:'s Avatar
Default Removing LCAs from an ITR
anyone have any advice on this topic?
Old Sep 14, 2002 | 02:57 PM
IN VTEC's Avatar
Default Re: Removing LCAs from an ITR ( Rob)
Which ones? Front or rear?
Old Sep 14, 2002 | 03:41 PM
Rob :190:'s Avatar
Default Re: Removing LCAs from an ITR (IN VTEC)
rear, sorry
Old Sep 14, 2002 | 03:55 PM
IN VTEC's Avatar
(3) 14mm bolts
.one to the hub
.one to the subframe
.one to the shock
(2 or 3) 10mm bolts
.for the ABS lines
Then, pull laterally on the brake rotor/hub to separate the arm, and follow up by pushing it down to separate it from the shock and subframe.
It's quick and easy. Shouldn't take longer than 20 minutes if you work fast....faster if you have an electric impact wrench.
Don't forget to anti-seize the entire bolt when you put everything back together.
Old Sep 15, 2002 | 06:35 AM
Rob :190:'s Avatar
awesome, thanks, it was no sweat.
Atomic1
14
Jun 4, 2011 03:41 PM
usmarinedelta
Dec 27, 2006 08:52 PM
Soda Popinski
Mar 30, 2004 05:18 PM
allicedout
Mar 27, 2004 09:54 PM
Ass_Clown
Aug 18, 2003 07:36 AM
