Question for h22 injectors
Hi I was just wondering is it okay to run injectors without resistor boxes for the h22 motors? Just wondering before I rewire my harness for it due to that i hear you need resistor boxes for h22's thanks guys! would love the help from you guys out there!
obd1 h22 injectors need resistor boxes if im not mistaken and the obd2 h22 injectors dont
Correct. There's something weird with the '96 injectors though, when Honda switched over to OBDII (but still on the h22a1, not h22a4) so technically they're OBDII but need the resistor box. Check part numbers and you'll be fine.
as for your h22 injectors, if they accept the obd2 clips (newer style) then they also do NOT require the resistor box
if they use the obd1 clips, then yes they need a resistor box as they are peak & hold injectors
