Check engine light because of o2 censor?
Got a 97 hatchback. I put a magnaflow cat back system on and now my check engine
Light comes on and says o2 sensor. My question is would a oem honda o2 sensor fix the problem? Car runs fine just want to fix it. Any help would be greatly appreciated.
Sometimes oxygen sensors can reverse polarity and cause a DTC after installing aftermarket exhaust components. I recomend removing the oxygen sensor, taking the pins out of the connector, reversing the white and green wires and plugging them back in. I've seen it a thousand times. Guaranteed fix.
