vtec killers stage 5 cams and ferrea rockers trades? offers?
Theese killers are awesome for all engine!!! I used to run a set of Todas back in the day, idle was shitty, but top end power was masing! Bump for a sick set up!!!
CRANE 253-0510 CAMS RACE ONLY CAM SET: B16A/B17A/B18C (PRO TURBO)
Crane Cams Race Only Roller Cam Set in 8620 Steel Billet - designed for pro turbo racer for Honda/Acura B16A/B17A/B18C (DOHC VTEC) Engine.
i want 1000.00 shipped for the setup.
CRANE 253-0510 4500-12500 rpm CAMS RACE ONLY CAM SET: B16A/B17A/B18C (PRO TURBO)
the cams and rockers have zero street miles ad very little run time the rockers have no scuffing like new
Race Only Roller Cam in 8620 steel billet
Designed for pro turbo racer
Crane Cams computer aided design features unique ”split duration” lobe profile design (exhaust duration is less than intake duration)
“Spools” turbo faster for quicker boost and response
Reduces turbo lag time
Check valve to piston clearance
RPM range 4,500-12,500
Grind Number Part Number
RHON-230/441-2SR-12 253-0510
Advertised Duration
Int/Exh - 254 / 248
Duration @ .050
Int/Exh - 230 / 224
Lobe Separation- 112
Gross Lift - 441/426
Advertised Duration
Int/Exh - 254 / 248
Duration @ .050
Int/Exh - 230 / 224
cloviskilla
Jun 29, 2010 06:56 PM
