fuel leak, f22b2, 95 accord wagon lx
Old Jun 27, 2010 | 03:57 PM
S1NFUL RL1 619's Avatar
Default fuel leak, f22b2, 95 accord wagon lx
so i have a fuel leak coming from my fuel rail i believe. although it's hard to pin point where the leak originates from because there's so much fuel dripping form all sides and lengths of the fuel rail front and back. i can't even run my motor for a minute and there's a huge puddle of gas building up on top of the IM.
has anybody else encountered this problem? i'm not a very mechanical person so i don't even know where to begin on fixing this issue. i'm looking for some help please. thanks!
Old Jun 27, 2010 | 04:03 PM
nus_dogg's Avatar
Default Re: fuel leak, f22b2, 95 accord wagon lx
Clean it up and have a second person to start up the car while you watch where it's spraying from. It could be the line around the Fuel Rail, rail itself, injector, etc.
Old Jun 27, 2010 | 04:12 PM
alright thanks... i'll give that a shot.
Old Jun 27, 2010 | 06:34 PM
ok, so i confirmed it's the fuel rail. i talked to a mechanic and he was saying that i should tighten down the bolts that are on the fuel rail, i haven't touched anything yet, but i wanted to get a second opinion before i start cranking away.
Old Jun 27, 2010 | 07:24 PM
GhostAccord's Avatar
If your mechanic said to tighten down the rail then go ahead and do it. It won't hurt anything to tighten it up if it's loose. I've never seen a rail come loose from the intake and leak though. Did he say if it was all the injectors that were leaking or just one or two?
Old Jun 27, 2010 | 07:38 PM
well the mechanic didn't actually look at my car. i spoke to him over the phone. i'd have to pay for him to even come by and check it out for diagnostics. the car leaks so much it went through a half tank in one day and i don't want to drive it anywhere. but i tightened down the bolts and still no success. i took a second look and it seems as if the leak is coming from the bottom of the fuel rail. would that mean it would have to be one or two of the injectors?
Old Jun 28, 2010 | 02:09 AM
I would have to assume that it is the injector O-rings. Remove the fuel rail and injectors so you can replace the 4 O-rings on the ends of the injectors. it's a fairly easy job if you have basic tools. Metric of course!
PM sent
Old Jun 28, 2010 | 07:26 AM
does working on this part of the fuel system require bleeding the lines or anything of that nature?
Old Jun 28, 2010 | 10:12 AM
Probably not, if your fuel is leaking that badly I would have to assume that there isn't very much pressure left in the rail.
Just as a precaution you could put a wrench on the banjo bolt (fuel line- fuel rail fitting) than wrap the bolt and wrench both with a rag. Loosen the bolt and the rag will stop any fuel from spraying. That's how I relieve the pressure anyway.
Old Jun 30, 2010 | 06:17 PM
alright, so it turned out to be the o-ring on the #2 injector... i had to buy a injector seal kit for $10 just for the small o-ring at the top of the injector. thanks for all the help guys! i appreciate it! the wagon is officially back on the streets! holler!
Old Jun 30, 2010 | 08:48 PM
phootbag's Avatar
Did you replace all of the injector o-rings?
Old Jul 1, 2010 | 09:27 AM
no, just the top one.. the tiny one at the top. i looked at the other o-rings and they were still in good condition no rips or cracking of any kind.
Redemption
Free Stuff
Feb 13, 2009 11:47 AM
johnwohl
Feb 10, 2008 11:07 AM
HpRevolution
May 23, 2007 09:42 AM
sohc1200cc
Nov 3, 2006 10:02 AM
