B18C5 w/Buddy Club Camshaft Kit w/various other ?'s
Old Jun 26, 2010 | 09:36 PM
JDM_nUt's Avatar
Default B18C5 w/Buddy Club Camshaft Kit w/various other ?'s
This will be a B81C5 stock motor, which I will be raising it's compression ratio w/Buddy Club head gasket, Spec III camshaft, and Cam Gear combo. There won't be any upgrading of the B18C5 bottom end. I've read various statements that the Buddy Club valve springs aren't needed, can anyone confirm this statement to be true and why? I will not be revving my RPM's past 9k, I'd like to get a good tune 1st and see what type of power I'd be making. It is possible to achieve 200+hp w/o hondata s300 along with I/H/E? I am I better off w/the hondata s300 that way I could set VTEC engament lower I.E. 5k to a 8.5K-8.9k red line, along with controlling the car's A/F ratio? The goal is to keep the car as "street able", w/o sacrificing reliability, is it possible to aheive 200+hp & 150lbs torque w/this set-up? Looking for experienced tuners recommendations to above questions that have built set-ups similar to this. All of these items will be put in all at once, thank you for your time & input.
Old Jun 26, 2010 | 11:36 PM
chewyv's Avatar
pm4nudes
Default Re: B18C5 w/Buddy Club Camshaft Kit w/various other ?'s
its a streetable cam. stock itr valvetrain is fine no need to upgrade. I think your end results will depend on your i/h/e set-up. Power cut off around 8400-8500. My b18c I went with 3" intake. itr t/b and i/m ported. hytech rep to 2.75 test and exhaust. s300. Its a good cam for dd.
Old Jun 27, 2010 | 05:11 AM
00Red_SiR's Avatar
All Motor Mentor
Every cam other than VTEC killers are streetable with correct tuning. The BC3's are a very nice cam to use on the street in a daily driver. You can run them on the stock ITR valvetrain but not past stock redline. If reliability is what you are after, CHANGE your valve springs or you will spend a lot of money later, trust me. You will need a tuning system like an S300 if you have any hope of even coming close to the magical 200 whp. In fact you will need a number of other good supporting mods like header, exhaust, intake etc.
Old Jun 27, 2010 | 08:57 AM
JDM_nUt's Avatar
I will purchase a Mugen Air Intake System, Fujitsubo RM-01A, 2.5 test pipe or aftermarket cat. I'm unsure about a exhaust manifold, I am considering a Buddy Club Header, along w/a thermal TB & IM gaskets. As far a porting the B18C5 head, I may micro polish it to get better air flow. Correct me if I'm wrong, would the above listed items get me my desired results?
Old Jun 27, 2010 | 11:58 AM
00Red_SiR's Avatar
All Motor Mentor
The Mugen intake is $$$ and it's good but out of everything I have ever tested or seen tested, it's hard to beat a 3" CAI like AEM or equivalent. That exhaust is decent, test pipe is fine if you don't want to use a high flow cat and so are the gaskets etc. The Type R head is great the way it is unless it has a lot of mileage on it and needs a new valve job. I'd send it to a head porter like CCCylinderheads for a good valvejob etc and go with that. I think the buddy Club header is another copy of the Hytech header out there? If so, it's good but probably more money than the cheaper copies. SMSP makes some good headers and is in Virginia, have a look at what he offers and see if it's in your price range. With some good tuning you should be up in the 190whp I would think, it all depends on how the dyno you're on reads.
Old Jun 27, 2010 | 12:06 PM
teg_racer's Avatar
68 or 70mm tb., endyn intake mani bismoto header and 2.75 exhaust and my bcIII cams that i have for sale
wwcrxww
Aug 19, 2012 04:05 AM
Stinkycheezmonky
17
Sep 18, 2007 03:27 AM
DarkSolPR
Feb 24, 2005 01:38 PM
^AnDre^
Nov 25, 2004 11:09 PM
RangerDan
Aug 12, 2003 11:55 PM
