RI 2000 impreza track ready car. $5k lots of mods
Up for sale is a 2000 aspen white 2000 impreza 2.5rs track car. Car has about 109k miles on it with new motor and tranny around 75k miles. I just replaced all 4 wheel bearings and one hub. Ac works all windows work sunroof works. Good to go... Body has a few dents and scratches and has a bad fender roll job but should be easy fix if wanted. To me it was a track car so i didnt mind.
Trades are welcome really looking for another miata but will take anything from a 240sx to a jeep wrangler or a street bike lol. Does not hurt to ask worst i can say is no.
For sale price $5000...
MOD LIST
SUSPENSION
BC Racing Coilovers
Whiteline ALK
Whiteline 22mm N/A Front Sway Bar
Whiteline 24mm WRX Rear Sway Bar
Whiteline Heavy Duty Rear Sway Mounts
Whiteline Front & Rear Sway Bar Endlinks
Whiteline Lateral Links
Whiteline Rear Strut Tower Bar
Whiteline Front Roll Center Adj Kit
Whiteline Rear Toe Lock Out Kit
Tein Front Strut Bar
STi Group N Rear Crossmember Bushings
STi alum Lower Control Arms
Super Pro GC Lower Control Arm Bushing
Super Pro Front & Rear Trailing Arm Bushing
BRAKES
Wilwood 6 piston front kit with slotted and drilled two pc rotors
Wilwood 4 piston rear kit also slotted drilled two pc rotors
Stainless brake lines all around
05 STi Brake Booster & Master cylinder
New ebrake pads
Fresh ATE Super Blue Brake Fluid
MRT Master Cylinder Brace
Wheels
White rota boost 17x8 +48
Hankook K104's 245/40/17
ARP Extended Wheel Studs all around
DRIVETRAIN
Drive Shaft Shop one pc Alum Drive Shaft
Techna-Fit SS Clutch Line
Super Pro Rear Diff Support Bushings
Super Pro Rear Diff Bushings
Kartboy Trans Crossmember Bushings
ACT Heavy Duty Clutch Kit
Fidanza Flywheel
Cusco Motor/ Trans Mount Kit
Kartboy Short Shifter
Kartboy Front & Rear Shifter Bushings
TIC Shift Linkage Update
TIC Shifter Pivot Bushing
Ixiz Concept Race Pitch Stop
OEM Clutch Slave
New Axels all around
Brande new wheel bearings not even 1000 miles on them.
ENGINE
Perrin Crank Pulley
Borla Headers
High flow cat
Stromung Cat-Back
Kartboy Exhaust Hangers
Kartboy Battery Tie Down
Braille no weight race battery
STi Radiator Cap
New gaskets, pumps, belts, seals on the "new" RS motor
'08 Subaru Magnetic Oil Drain Plug
Walbro Fuel Pump
INTERIOR
Splash Sports Steering Hub
Sparco Steering Wheel
WRX Pedals
STi Spec C Shift ****
Shifter extender
lag bolts for harness
EXTERIOR
Wingless Trunk
Subaru License Plate Bracket
Osram Headlight Bulbs
McColluch HID's in the Fog Lights
ebay STi Fog Light Covers
JDM Tail & Corner Lights
ebay Clear Side Markers
Tein Hood Dampers
AEM Intake
Also comes with spare tranny. Not sure if its good or not but always use for a ra gear set or core for rebuild.. Also have some spare brake rotors and a box of stuff.
pics can be seen here. Sorry photobucket was being dumb!
http://viewmorepics.myspace.com/inde...lbumId=3272297
Any questions just ask....
MOD LIST
SUSPENSION
BC Racing Coilovers
Whiteline ALK
BRAKES
New ebrake pads
Wheels
DRIVETRAIN
Fidanza Flywheel
OEM Clutch Slave
ENGINE
Perrin Crank Pulley
Borla Headers
High flow cat
Stromung Cat-Back
STi Radiator Cap
Walbro Fuel Pump
INTERIOR
WRX Pedals
Shifter extender
EXTERIOR
Wingless Trunk
Tein Hood Dampers
AEM Intake
Trade for this?
PICS
http://s416.photobucket.com/albums/p...keconobox/Car/
1999 Civic Si with 98XXX on the body.
Engine/Trans
1997 JDM ITR B18C with roughly 60XXX
VteccKidd RMF Style Narrow Header
J's Racing Carbon Fiber Intake
Apexi WS2 exhaust
Clutchmaster Stage 3 Carbon Kevlar Clutch. (needs replaced.)
Quaife LSD
ATS 4.9FD
B&M short throw shifter
Will include a Nitrous Kit. When I bought the car it was being sprayed. recently rebuillt the motor. has less than 1000 miles since the rebuild. has not been sprayed in the 2 years I have owned it. Will also need a new clutch but I am taking care of that.
Suspension/Exterior
Tokico Blues with Skunk 2 springs
Kuhmo Ecsta SPT dont have a size right now but I will get that for you.
16" Work Emotion CR-KAI
At one point I had a VIS racing carbon Fiber hood. Sold that cause I needed money. Bought a hood that someone had done an acid bath on and sanded it down and turned it into a chalkboard hood.
Interior
Del Sol SI seats. They sit a little bit lower than the stock ones.
Fusion Audio Ipod receiver
All Fusion Audio components.(tweeters, amps, door speakers, 6x9's)
Fusion audio 12inch sub.
The Bad:
NO A/C. Should have that before Import Alliance.
NO P/S If you want it then I can try and track it down to reinstall
NO Cruise.
Minor chips here and there. its an 11 year old car. ill try and get some of them fixed.
Front lip is pretty bad. the car sits very low and on these KY roads the front lip takes a beating. Ill try and get that replaced as well
Let me know if you are interested
PICS
Engine/Trans
Apexi WS2 exhaust
Quaife LSD
ATS 4.9FD
Suspension/Exterior
Interior
The Bad:
NO Cruise.
long shot, but trade? http://www.hondamarketplace.com/show....php?t=2797528
sorry this link should work.
hey my buddy linked me to this, i just crashed the twin to this car on monday and need a new one, ill have insurance $$$$$ soon, and i also have a 96 fullsize ford bronco with 31's id trade plus cash for it, pm me me and let me know
Pdahondas88
22
Apr 7, 2018 09:46 AM
96 SOHC VTEC
Jun 12, 2002 11:09 AM
