B16a1 swap question(s)
Old Sep 14, 2002 | 12:01 PM
88EF's Avatar
Default B16a1 swap question(s)
Hi, I'm new here. I drive a 88 Civic Hatchback STD. I've been wanting to do a b16a1 swap for a long time but I'm not sure on exactly all the parts I need. I was planning to get all the stuff, and then spend a day with friends putting it in. I'm also confused about this dual point injection wire harness thingy. I don't get it. If I buy a complete swap, doesn't it come with a b16a1 ECU and wire harness? It would make sense to just put in the new ECU and route the b16a1 wire harness through the firewall and plug all the sensors in the right spots, so why would a rewired harness be necessary? Any help would be appreciated.
Old Sep 14, 2002 | 02:45 PM
90-CRXSi's Avatar
Default Re: B16a1 swap question(s) (88EF)
you use your existing wires when doing the swap, so if you don't have MPFI yet, you wont be wired for it.
1990vtecsedan
Nov 8, 2012 03:00 PM
EF8DayDreamer
Mar 21, 2012 11:52 AM
krazyk
Dec 12, 2006 05:13 PM
stemiched
Aug 8, 2006 09:45 PM
h22blazerz5
Dec 31, 2005 07:53 PM
