5th Gen OBD1 Swap Help!
Old Jun 25, 2010 | 10:51 PM
AznXstazy's Avatar
Default 5th Gen OBD1 Swap Help!
hey guys, i did a jdm obd1 f22b1 swap into a 5th gen OBD2 car. the only way for it to work is either swap over a OBD2 oil pump housing and bolt up the 2 sensors needed there OR get a OBD1 H22/H23 dizzy and extend the 4 wires from the oil pump to the dizzy.
I choose to use a OBD1 dizzy and extend the wires. seemed like a little bit easier to do, BUT i have a problem now. for some reason the car keeps throwing a CODE 15. (Ignition output signal) I can NOT find out what the issue is. I swapped out EVERYTHING.
NEW:
ignition switch
coil
tried BRAND NEW and 2 REBUILT dizzy (autozone dizzys but still should be fine)
double checked the wiring, but i can NOT get rid of this code. the car starts up FINE, but give it a min at idle and it will slowly cut off. i checked for power at the ECU and it shows I'm getting power on the YELLOW/GREEN. which should be the IGN Output signal
ANY HELP OR ADVICE WOULD BE GREAT. thanks guys
Old Jun 29, 2010 | 05:05 AM
AznXstazy's Avatar
Default Re: 5th Gen OBD1 Swap Help!
ttt
Old Jun 29, 2010 | 11:50 AM
1GPlusSH's Avatar
have you checked the FAQs to make sure you're doing everything? i had to do the OBD1 conversion, and everything you said sounds like everything. i'd check there.
Old Jul 20, 2010 | 11:08 AM
AznXstazy's Avatar
anyone know the color code for the ignition output signal wire?
PrecisionH23a
Feb 14, 2019 11:55 AM
despat
Apr 2, 2010 02:56 PM
turbotime
Sep 25, 2006 07:04 AM
ebe
Mar 20, 2004 09:19 PM
