Urgent plz help... b16 fuel cut at 3200 rpm? why?
Old Sep 14, 2002 | 11:50 AM
90civichbsi's Avatar
Default Urgent plz help... b16 fuel cut at 3200 rpm? why?
like the topic says, i have gotten my b16 to running, it idles just fine, but once it hits 3200 rpm, the fuel cuts off, what could this be
btw i am running the b16a1 in a 90 civic si?
anyone know plz help
Old Sep 14, 2002 | 12:04 PM
letsride's Avatar
Default Re: Urgent plz help... b16 fuel cut at 3200 rpm? why? (90civichbsi)
What ecu?
Old Sep 14, 2002 | 12:22 PM
Default Re: Urgent plz help... b16 fuel cut at 3200 rpm? why? (letsride)
its a pr3
Old Sep 14, 2002 | 12:29 PM
salbaje's Avatar
try a different ecu and see if that solves your problem.
Old Sep 14, 2002 | 12:31 PM
Default Re: Urgent plz help... b16 fuel cut at 3200 rpm? why? (salbaje)
where could i get another ecu? im in dallas tx
Old Sep 14, 2002 | 12:41 PM
JDM88EF9's Avatar
My friend that had a 90 integra with a LS/VTEC had this same problem..... The car is suppose to have fuel cutt at 8500 rpm but it started to cutt of at 6000 rpm.... So he figured that ecu was fucked up but when he changed it for another GS-R computer that same problem happened. Then he figured out the problem, the ecu was getting hott ont he floor so he put it under the seat on the carpet and the problem was sloved...
Weird if you ask me!
Old Sep 14, 2002 | 01:06 PM
Default Re: Urgent plz help... b16 fuel cut at 3200 rpm? why? (JDM88EF9)
anyone have any other ideas?
Old Sep 14, 2002 | 02:23 PM
letsride's Avatar
Are you getting any codes at all? I would try to check with another ECU and also re-check all of the gound connections.
Old Sep 14, 2002 | 04:32 PM
well i just did some checks, and i found out its not a fuel problem, but an ignition problem, its not getting any spark.. not throwing any codes, ive checked all the wires, checked the timing a couple times,
it idles and runs perfect, but once it hits 3200 the ignition begins to pulsate, it wont go any faster and black smoke (unburned fuel) blows out my exhaust..
anyone have any idea?
[Modified by 90civichbsi, 3:11 AM 9/15/2002]
Old Sep 14, 2002 | 06:10 PM
come on anyone ever expirienced anything like this, or know what it is?
Old Sep 14, 2002 | 06:11 PM
Urban Business
Guest
Posts: n/a
trank angle sensor wiring is fuct up re check that (dizzy wires)
Old Sep 14, 2002 | 06:13 PM
Default Re: Urgent plz help... b16 fuel cut at 3200 rpm? why? (TorteX)
if thats the probleem, what exactly ydo i need to do here?
Old Sep 14, 2002 | 06:23 PM
USDM 4G VTEC's Avatar
i was goin to say that.... i have experienced that twice...
its the CKP crank angle sensor on the dizzy.. sends rpm signal to ecu.... and makes it cut aroun 3500..... check that u dont have the CKP cables reversed on the dizzy... and if they are right, switch them... i had that problem even with my Z6... i can bet 5 bucks to it.... try to use another dizzy.... check ecu .. ususally it givesw a code 4..
Old Sep 14, 2002 | 07:25 PM
djay86's Avatar
Default Re: Urgent plz help... b16 fuel cut at 3200 rpm? why? (JDM EF9)
ive had similar problems as well! let me explain...
Sometimes when starting my car, i get an immediate CEL.. so im like ok? The car idles kinda rough, and i go to take off and boom, fuel cut off at around 3k. So I usually just turn the car off, and wait, sometimes the CEL goes away sometimes it doesn't. I always wait for it to.
Also when i put my car in reverse, the Gas goes crazy, and i get alot of unburnt fuel coming out of my exhaust and i get a crazy CEL flashing on and off.
I have a B16a in my CRX HF.
Old Sep 14, 2002 | 08:02 PM
Default Re: Urgent plz help... b16 fuel cut at 3200 rpm? why? (djay86)
ok.. we tried a number of things checked wires on the dizzy, but...
im getting a CEL but the light on the ecu doesnt blink it just constantly stays on, what does this mean?
Old Sep 14, 2002 | 08:25 PM
ricodemus's Avatar
I had this problem exactly. try resetting the ecu
Old Sep 14, 2002 | 10:03 PM
Default Re: Urgent plz help... b16 fuel cut at 3200 rpm? why? (ricodemus)
i took out the hazard fuse for 10 seconds, is that not long enough?
did the cutt at 3200 rpms happen to you too?
Old Sep 15, 2002 | 01:39 AM
Wiz's Avatar
Wiz
I'm having this problem too, I didn't know what the heck it was, I changed the distributor it still happens everyonce in a while, I just turn the car off then back on and the cel goes off and its back to normal, I think whoever said the ecu was getting hot might be right though, or maybe its a combination of both
Old Sep 15, 2002 | 03:48 AM
boostedhb's Avatar
Default Re: Urgent plz help... b16 fuel cut at 3200 rpm? why? (Wiz)
It is either the ignitor is going bad, Is your tach bouncing at all? Or it could be the map sensor
Old Sep 15, 2002 | 10:39 AM
Mugen Dom's Avatar
Default Re: Urgent plz help... b16 fuel cut at 3200 rpm? why? (boostedhb)
id say a bad igniter also..take the one from ur old dizzy and see if that works
Old Sep 15, 2002 | 03:37 PM
Default Re: Urgent plz help... b16 fuel cut at 3200 rpm? why? (JdMB16Ahatch)
i dont think its the ignitor, it idles perfect, anything else?
im gonna call HMO tommorrow to see what they say, if any of you can think of anything let me know
Old Sep 15, 2002 | 07:01 PM
Mugen Dom's Avatar
did u try and swap the igniter???? because ive seen this a few times and it was the igniter my igniter has gone a few times and it idled fine fuel cut out at 6k
Old Sep 15, 2002 | 07:31 PM
we found out its the ignition that cuts not the fuel
Old Sep 15, 2002 | 07:44 PM
Mugen Dom's Avatar
like i said igniter try it please prove me wrong or something u have to have ur old distirbuter laying aroud i know its the spark thats doin it not fuel but im a lil tired and typed fuel like a moron....nowe try it please
Old Sep 15, 2002 | 08:22 PM
i will, i just have to go get the old dizzy and try it out
