My Northwest EF Build
Old Jun 25, 2010 | 06:09 PM
b1_teg_god's Avatar
Default My Northwest EF Build
So.... i bought this EF a few months back with a blown up b series in it i guess the guy who owned the car before me purchased this engine from his friend who worked at ground zero what the previous owner i guess didn't know is that they just really weren't that good of friends so he was sold a b16 with eagle rods with wiesco low compression pistons pretty decent build but the motor only ran 4 hours because they had the crank turned and used stock sized bearings in the bottom end so you can only imagine what happened..... this is the car when i first picked it up....
also i need to throw out some thanks on this one this is my first full build ive done a few turbo cars but not a full build and not a NA so thanks to:
Charlie
Nathan
Brian nathan's neighbor
Evo man (John)
Victor (My Bro)
My Dad
Brian W.
Jeremiah
Old Jun 25, 2010 | 06:17 PM
b1_teg_god's Avatar
Default Re: My Northwest EF Build
so i took it home and i pulled the b16 out and i checked for salvageable parts i can use what i did know i could use was...
-hasport EF b sereis mounts
-hasport adjustable shift linkage
-obd1 p61 chipped ecu
-obd0-obd1 jumper harness
-exhaust which was a nice full apexi N1 header back with a lame dc sport header
-aem intake
and thats about all i knew i could use here some pic of removing the old b16 with the hole it the block lol....
that guy in the picture is not me thats my boy charlie hes helped with damn near every step of this build and i owe my boy some props so thanks char and you know ill be helping you ever step of the with yours o ya keep your eyes peeled for his ef build it will be under my northwest built ef 2
Old Jun 25, 2010 | 06:22 PM
DCRB's Avatar
nice car meng. props for an oregon guy
Old Jun 25, 2010 | 06:27 PM
b1_teg_god's Avatar
after thinking of what i should put in this bad boy and after doing boosted cars over the last couple summers i decided i should build an all motor car this summer, so the hunt began for parts while sitting at home pondering one day my buddy called me he was gonna move and needed to liquidate everything he has so i drove 3 hours to his house and he made me a pretty amazing deal on a ls motor with a chipped piston, a b20 b motor that was boosted and had a few cracks in in the sleeve very small ones and a perfectly good sir II b16 with p30s with under 40k that was in a rhd halfcut, a set of 97 spec type r cams and valve train, a type r intake manifold, a ls vtec kit that was on the turbo b20, and a set of arp head stud bolts missing all the nuts and washers lol.......
Old Jun 25, 2010 | 06:33 PM
BrayzieEF9's Avatar
this thread needs more pix
Old Jun 25, 2010 | 06:37 PM
b1_teg_god's Avatar
so i came home and i pulled the ls apart and it was a beatiful block so i decided thats what i was gonna use the down fall was it spun a bearing.....
so i pulled the b20 apart flawless rods and crank beautiful actually nicest i've ever seen in person lol.. so i decided i'd use these in the ls block.... when i went to go remove the crank i found a stripped the hell out flywheel bolt :0 but no worries me and a few buddies PROPS to nates welding... brians co-piloting and welder and me sack and evo man standing around and watching we got it out heres a pic lol dont worry we did it in super small spot welds so we didnt transfer heat through the crank and warp it... this is how us oregon boys do thangs lmao..... not to mention three of the guys i mentioned above race hondas aswell on a dirt track lol sick cars and thanks for all the help you guys
so i turned my attention to the b16 i wanted the p30's out of this engine so i pulled the whole thing apart and had just the pistons and rods. after this i called it a night
the next morning i rolled over to the local machine shop ordered a set of arp rod bolt and dropped of the b20 crank and rods and had him press the b20 pistons of the rods then i pulled out the b16 pistons and rods and had him do the same we indexed the rods and i told him i want the 1.6 piston on the pr4 rods and the rod bolts installed as wheel i wanted the pistons magnafluxed and the rods shot peened and everything balanced the best he could a few days later this is what i picked up....
Old Jun 25, 2010 | 06:49 PM
b1_teg_god's Avatar
Old Jun 25, 2010 | 06:50 PM
b1_teg_god's Avatar
so after receiving all the parts i needed to put the bottom end together me and nate got the block on the engine stand and nate proceeded to put the most aggressive cross hatch he could with a bottle hone and a chicago harbor freight drill lol looked great he did an awesome job i really was impressed and people really shouldn't bag on nate when it comes to building a motor hes no brian but he gets the job done and it runs..... thanks buddy
Old Jun 25, 2010 | 08:39 PM
k20rex's Avatar
nice car, i'm from the northwest also = )
Old Jun 25, 2010 | 09:15 PM
BrayzieEF9's Avatar
i think most of the ppl posted in this thread is from the northwest
Old Jun 26, 2010 | 01:18 PM
b1_teg_god's Avatar
thats cause the northwest is the shiz!!!! i need to find a jdm b16 cable tranny anyone have one
Old Jun 26, 2010 | 01:37 PM
CR-X VTEC's Avatar
Convert that **** to hydro I got a LS hydro trans w/LSD for ya.
Old Jun 27, 2010 | 05:50 PM
BrayzieEF9's Avatar
lol just hate going to seattle,those roads are ****ed up,that city needs a warning sign for there roads.last time we were mashing around seattle.there was a lil road work ramp and there was no warning sign we caught air LOL
Old Jun 28, 2010 | 01:21 AM
b1_teg_god's Avatar
so after the hone was done we cleaned the cylinders with lots of brake clean and paper towels until nothing showed up on the cylinder walls then we proceeded to install or crank
Old Jun 28, 2010 | 01:29 AM
b1_teg_god's Avatar
Now was the next step now i know a lot of people may like using oil to coat the cylinders walls and have always have had a good experience with ring seat that way but with us we do not do it that way any more picked up on a trick from a write up Larry at endyne were he used a old nascar trick were they would put the most aggressive cross hatch they could and use wd-40 to coat the cylinder walls with and what this did was one engine start up it created friction and just dug the rings into the cross hatch and most the time you got an awesome ring seal so in this case we went this route and began to install the pistons rings....
Old Jun 28, 2010 | 01:40 AM
b1_teg_god's Avatar
so after installing everything needed into the bottom end i took the shortblock back to my house and started install everything needed on in all the way up starting with the oil pan :0
and yes thats me working on the engine and in the egine bay soldering some wires lol
Old Jun 28, 2010 | 01:45 AM
b1_teg_god's Avatar
so after i was done putting the whole long block together me and charlie were in a quick hurry to get this bad boy in the ef so we worked through the night to get it done
Old Jun 28, 2010 | 01:53 AM
b1_teg_god's Avatar
so after getting it in the car it idled at 2k which is not good when your trying to brake in a motor and it wasn't the throttle body and it smoked super super bad but i put the new shoes on it and got some pics.... i'm not really digging the wheels i thought it would look better then it does in my head lol so i'm considering purchasing a set of white rota track r's or trading some one for a new set of wheels these have brand new 50 series rubber on them 195/50r15
or rockin these till i can get some baller wheels likes some mugens or something i dont know
Old Jun 28, 2010 | 02:01 AM
b1_teg_god's Avatar
so here is whats goin on at this piont i pulled the head back of and i found oil on the back side of the throttle body and in the type r intake manifold so that lead me to believe in was valve stem seals so i pulled the head back of and sent it to the machine shop who might i add is one of the most amazing guys i have ever spoke to when it comes to motor i would suggest him any day hes local here in central oregon but he has everything including a flow bench and he does awesome work for amazing prices and hes a genius lol he owns rocket engineering in prineville oregon its worth the travel..... so i havent taken pics of how the cars sitting right now but here is pics off the head i just got back a few days ago after he fixed it and found out i had four bent valves besides the two i already had replaced in the first.... so he replaced the valves and did a 3 angle valve job and repleced the valve stems seals through to whole head installed factory dual stage valve springs and milled the head and cleaned the head and gave it back in less then a week..... Also i found out that i forgot to tighten the intake manifold bolts lol and i figure thats was the cause for my high idle problem.....
Old Jun 28, 2010 | 02:07 AM
b1_teg_god's Avatar
so now i picked up a set of 00 ctr cams and a new set of nicer adjustable cams gears so im gonna pull the motor back out put it back together and degree in the cams and get a new header and get rid of the dc sports header i have if any one is interested and try to get the combustion and volumetric efficiency as close to perfect as i can and seee if i can hit 200 whp using all oem parts also i need a new b16 cable trans i have this supposed jdm s1 cable trans that i haven't ran yet but he told me it had a grind into 3rd and i cant stand a grind so if any one is interested in that aswell let me know and if you have a real gsr ys1 or a j1 let me know i think im also picking up a y1 that has no grinds it just pops out of 5th all the time i guess
Old Jun 28, 2010 | 02:35 AM
static-x's Avatar
well hello fellow bend person.
Old Jun 28, 2010 | 09:27 AM
Captain Key!s's Avatar
Looks good...please use a period, comma, semi-colon where applicable.
Old Jun 28, 2010 | 01:34 PM
b1_teg_god's Avatar
yes i'm a fellow bend guy and i see you know bruce are you one of those gay touge guys??
and i'm sorry about my punctuation i was raised by wolfs...
Old Jun 28, 2010 | 09:44 PM
fmxfreak1187's Avatar
dude sick thread ill probably make a more organized one for mine that does not start off with "so" on every post lol and dont make fun of those touge guys man they might put zip ties on your car when your not looking...
over all well done! we still need to make official plans for my ef swap
Old Jun 28, 2010 | 11:21 PM
jdm36's Avatar
awesome build car looks good
