Vtec Solenoids
My vtec solenoid on my D15B went bad. I'm trying to find out what solenoids are compatible. Anybody know off hand. I tried researching but I'm at work and so much is blocked it's very hard to search.
D16 compatible?
B16 compatible?
Or only another 1.5 SOHC will work?
hAlp me please! I'm very tired of my CEL coming on every day.
D16 compatible?
B16 compatible?
take your solenoid off and see if the screen is dirty, if its clogged then clean it an reinstall and see if that clears your check engine light
if it doesnt clear the code then any vtec solenoid from a d or b series engine should work
Cleaning would probably solve your problem, unless it's actually broken off or something.
From the research i have seen, many people say that D, B and H series are all inter changable
You need to research what vtec actually is. It's not a turbo for your honda and there is not bigger upgrade on your vtec.
As for the people that said they are all interchangeable, they are not. And I need a new solenoid all together. I've already taken mine off and cleaned it.
Originally Posted by thumper64
D16Y8 won't work, but a D16Z6 or B16/18 will.
I want to say the D15Z1 VTEC-E solenoid should be the same as the Z6 VTEC. And as far as I-VTEC, idk what has that offhand. The 3 stage VTEC is an oddball.
If we want to get technical, the D16Z6 solenoid is not the same as the B series. Both will work on either D or B series motors, but they look different.
just buy another d15 v-tec e solenoid and u wont have any problems. why make it so difficult. the way it works is alil diff then the other solenoids. a y8 would probably be the closest to matching since it was a solenoid from a 96+. anything before 96 has the same solenoid and some b series fit them as well. such as a b series will fit a z6 but thier is no advantage from it what so ever
Thanks for the help everyone.
stickywhiteEH2
May 19, 2004 08:11 PM
Ignitecivic
11
Nov 10, 2003 06:46 PM
