how to test LSD
Old Sep 14, 2002 | 11:06 AM
johnzm's Avatar
Default how to test LSD
i see a post of a broken one, and the trany i got has trashed synchros. how can i test the LSD to see if it is stil intact or nt
Old Sep 14, 2002 | 12:21 PM
LoooseGSR's Avatar
Default Re: how to test LSD (johnzm)
Burnout?
Old Sep 14, 2002 | 02:05 PM
Losrocket_'s Avatar
Default Re: how to test LSD (PSUCRX)
I think the only way to be positve it has one , if it isnt stamped on the tranny itself, is to pop out the axles and you should be able to see all the way through. open light on each side.
Old Sep 14, 2002 | 02:08 PM
johnzm's Avatar
Default Re: how to test LSD (Losrocket'91)
i put the motor in. it had an lsd in the trans. i just tested it, and it looks fine
im thinking i just hit it so hard that i got both tires spinning accidnetally :D
Old Sep 14, 2002 | 02:47 PM
Monty's Avatar
Cant you jack up the car, spin one tire by hand and see if the other spins? That should tell if the gears are good atleast.
Monty
Old Sep 14, 2002 | 02:48 PM
E-AT_me's Avatar
jack the car up. spin one front wheel. if the other one spins the same way, then LSD. if it spins the other way, then no LSD.
poormans_typer69
Dec 20, 2006 10:59 AM
98oRange
Apr 8, 2005 06:45 PM
Wrath of VTEC
Dec 1, 2003 12:04 AM
Cyber ITR
13
Oct 10, 2002 06:58 PM
fred92htch
May 6, 2002 10:02 AM
