steering issue
I just replaced the driver side front caliper. Everything went smoothly. Bled the brakes, test drove, everything seemed fine. Anyways, drove to class today, and as I turned into a parking spot, I felt my steering wheel lock for a second. I pulled in then started to play with the steering wheel. It would turn a bit, lock for a second, keep turning, lock for a second and so on. Both directions. Any ideas? The car is a 98 ex coupe.
i'm sorry if this has been covered before - i'm in class right now and don't have time to search or check the car. I'm also in a rush because I have to drive to the airport later today :s
thanks in advance!!
thanks in advance!!
It doesn't sound like it has to do with the brakes. I had this problem on a truck and it was the steering box. Every quarter of a turn or so it would feel like it locked up and you had to fight it to keep turning the wheel.
