OBD0 Code 15?
I know your supposed to count long flashes as your first number and short ones as your second, but what happens if theres just 15 flashses, no order nothing. just 15 reasonably fast flashes, is that code 15?
Reason asking my car starts but after like 10-15 minutes it dies. ive put on new fuel filter, new main relay, its a 88 civic DX d15b2
Any and all help would be nice.
OBD0 D-series ECUs do not use long and short flashes, only short flashes - the number of flashes between pauses is the code - 15 flashes is a code 15 for the igniter in the distributor - check out the igniter, probably needs replaced - common problem
okay. have a CRx with an old school swap. this is an 86 crx, but has been wired iwht everything from a 91, including the pm6. im getting code 15 as well. figured since everything was 91 spec, the question belongs here.
obd0 pm6 from zedon. (known working)
hondata harness
hasport everything else
obd0 91 b16a
gsr cable trans
replaced the icm. looking to source a td22u ignition coil. atleast need a part number.
hondata harness
obd0 91 b16a
gsr cable trans
