bad Cat & misfire-which comes first
Old Jun 25, 2010 | 03:59 AM
janek's Avatar
Default bad Cat & misfire-which comes first
Also, where is back 1 oxygen sensor?
Old Jun 25, 2010 | 04:13 AM
97Preludeguy's Avatar
Default Re: bad Cat & misfire-which comes first
A bad cat will not cause a misfire. The extra unburnt fuel due to the misfire is what overheats/melts/clogs the cat.
As far as "back 1 oxygen sensor" It sounds like you're taking a reading from an OBD scan tool, which would usually say something like "bank 1 sensor 1" "bank 1 sensor 2" etc. What year Prelude do you have? Also is it saying the o2 sensor is bad, or the Heating circuit? I see the heating circuit go bad much more often.
BTW, it's also possible that the o2 sensor is fine and that it's receiving a faulty reading due to the cat being clogged which could make the CEL come on, so if I were you I'd fix the cat then reset the ecu and see if the o2 sensor CEL comes back. And get that misfire figured out too so you don't go through another cat.
Old Jun 25, 2010 | 11:39 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
How do you know the cat is bad. More often than not you have a faulty O2 and it is incorrectly saying the cat is bad.
rjmq06
Sep 12, 2010 03:05 PM
janek
Jun 25, 2010 02:16 PM
shawn_crx
May 20, 2009 09:29 PM
lilLB
Jun 22, 2006 02:44 PM
