HELP!!!!: vtec studders and wouldn't engage till 6500rpms and cut at 8000
Old Sep 14, 2002 | 10:40 AM
Type-Rare#1248's Avatar
Default HELP!!!!: vtec studders and wouldn't engage till 6500rpms and cut at 8000
could someone please tell me wuts wrong with my car??...I was at the 1/4 mile strip and my car's vtec wouldn't engage until 6500rpms and it goes on and off till 8000rpm's where it cuts fuel?
I am totally puzzled cuz i even made sure my car was fully warmed up
someone please help
Old Sep 14, 2002 | 10:42 AM
Reid's Avatar
Global Moderator
Default Re: HELP!!!!: vtec studders and wouldn't engage till 6500rpms and cut at 8000 (Type-Rare#1248)
Do you have a CEL by any chance?
Hint: CEL = Check Engine Light
Old Sep 14, 2002 | 10:43 AM
Default Re: HELP!!!!: vtec studders and wouldn't engage till 6500rpms and cut at 8000 (Reid)
nope...everything seems fine...no lights turn on
B2FiNiTY's Avatar
Oil level?
Old Sep 14, 2002 | 10:45 AM
rs's Avatar
rs
Well my VTEC does not engage until 6000 to 6500 rpms. Our tachs suck so when you accelerate real fast the needle gets a lot of momentum and you get a false reading. As for cutting off at 8000 that is odd. Mine cuts off at 9000 when I accelerate real fast. Try the search and check your oil and stuff.
Default Re: HELP!!!!: vtec studders and wouldn't engage till 6500rpms and cut at 8000 (B2FiNiTY)
Oil level?
if oil level is low, would it show on my dash/tach??
[Modified by Type-Rare#1248, 12:46 PM 9/14/2002]
Old Sep 14, 2002 | 10:46 AM
Default Re: HELP!!!!: vtec studders and wouldn't engage till 6500rpms and cut at 8000 (rs)
no, my tach is pretty accurate...normally vtec comes on 5700rpms indicated
Old Sep 14, 2002 | 10:49 AM
Reid's Avatar
Global Moderator
Bad tank of gas?
I mean if you changed nothing on your car and aren't throwing any codes, it is really hard to diagnose the problem.
Was your car taken into a shop for any work recently?
Old Sep 14, 2002 | 10:50 AM
B2FiNiTY's Avatar
How about spark plugs and wires?
Old Sep 14, 2002 | 10:52 AM
Bad tank of gas?
i got a new tank of gas and it's still like that
my car was taken to a shop, but only for body reasons
Old Sep 14, 2002 | 10:53 AM
didn't check that...could that cause the problem i described??
also, i have never resetted my ECU after my mods...could that be the reason??
Old Sep 14, 2002 | 10:55 AM
Reid's Avatar
Global Moderator
Try changing your cap and rotor.
Old Sep 14, 2002 | 10:57 AM
B2FiNiTY's Avatar
Highly doubt it.
Old Sep 14, 2002 | 11:00 AM
could you please tell me where the cap and rotor is?
Old Sep 14, 2002 | 11:01 AM
Reid's Avatar
Global Moderator
Try taking your car to a shop and asking them to change your cap and rotor.
Cap and rotor are parts of the distributor.
Old Sep 14, 2002 | 11:05 AM
thanx
Old Sep 14, 2002 | 11:22 PM
I drove my car again today and the oil light came on...so my problem was probably oil related
i am currently using mobil synthetic oil but i heard people say that oil burns too quickly
i want to switch to red line but is it okay to put 2 bottles in without draining out the remaining mobil oil first??
Any help is appreciated
Old Sep 14, 2002 | 11:27 PM
Bbasso's Avatar
Dude, stay with the Mobile 1 just ck it every 500miles or after a hard drive. thats seems to be your problem- No oil.
Let us know how low you were on oil.
(Also ck your gas cap if its not on it could cause a problem)
Old Sep 14, 2002 | 11:35 PM
Default Re: HELP!!!!: vtec studders and wouldn't engage till 6500rpms and cut at 8000 (Bbasso)
thanx for the advice
Old Sep 15, 2002 | 08:22 AM
unKnown's Avatar
screw your oil
what did you run chinaman
did you meet your goal?
Old Sep 15, 2002 | 08:45 AM
Default Re: HELP!!!!: vtec studders and wouldn't engage till 6500rpms and cut at 8000 (unKnown)
screw your oil
no not my goal
but i did run 15 flat with half my vtec working
Old Sep 15, 2002 | 09:27 AM
unKnown's Avatar
holy moly your up pretty early
i thought your like ant and those guys who sleep till friggin 3pm
do you still have your slip? post up the times for your slip!!!
[Modified by unKnown, 10:28 AM 9/15/2002]
Old Sep 15, 2002 | 09:38 AM
Raymund's Avatar
New User
could be the following:
1v-tec solenoid. check voltage and oil pressure
2broken oil pump which in case could mean low or no oil press.
Oil light you say? Dont drive the car and have it towed. Start the car only to check oil pressure.
Old Sep 15, 2002 | 11:59 AM
yes...i'm up early everyday
i don't have a scanner but i'll show you my slips in person
Old Sep 15, 2002 | 12:01 PM
Default Re: HELP!!!!: vtec studders and wouldn't engage till 6500rpms and cut at 8000 (Raymund)
i don't think it's the vtec solenoid
My bumper is filled with black dots so i think im burning oil...wut could be the reason for that??
