95 accord wont start..can someone help me?
i have a 95 accord with a f22b1..today i was driving down the road and all of a sudden my radio goes out..then a little down the road my rpm gauges turn off and my headlights to..i finally got the car home and i everytime i jump start it it turns on but once i unplug the jumpers it shuts off..i went to pepboys to check the alternator and battery..they both were good but i cant find out the problem..can someone help me
The battery is low on charge and the alternator isn't putting out enough voltage to run the car. The car was running on battery power alone until you drained it completely, at which point the accessories started cutting out because they didn't have enough power to run.
What exactly did they "test" for you at Pep Boys and what were the results? Did you receive print-outs? What voltage is the alternator putting out? How many amps is the battery putting out?
Check the fuse for the alternator circuit to make sure it isn't blown. A blown alternator fuse will prevent the alternator from charging the battery.
when i went to pepboys..they checked the alternator and it came out perfect..i forgot the voltage readout but they said it was fine..and the battery is brand new and i still checked it and it was good
mytest23
24
May 6, 2015 07:29 AM
BobRodgers3
Sep 22, 2012 06:40 PM
lmike6453
Jan 16, 2009 06:55 PM
