Car Pulling to the right...
Out of knowhere my car started pulling to the right - the faster I go the faster it pulls - does under acceleration and without - braking makes no difference - just put new pads and rotors on (Car pulled previously) - just had it aligned - pressure is 32 psi on all tires.
The only thing I can see on the tires is that the outside of the tire there are some "fray" marks on all 4 tires.
Any ideas what I should check? Or how I can diagnose what is bad?
Thanks
Thanks
make sure you radius rod locknuts are still tight. If the alignment shop set the caster and didn't replace the nut, it can come off.
What you mean by "fray". tires should never be frayed.
