ExplicitSpeedPerformance the only shop that sells Auto trans mounts for 96 accord?
I'm doing a swap for my bro and had ordered some mounts from innovative and they sent me F20 mounts. The swap i'm doing is from an F22B2 to a F23A yet i'm keeping the trans auto (i got H22 Auto) and reusing stock F22B2 intake manifold, distributor, crank pulley and harness. Innovative's kit thats for a F20 appeared it would all work except for trans mount. I know explicitspeed makes these auto mounts but last time i called their turnaround time was weeks. Anyone know if there are other companies that make auto trans mounts? Also who else has done this swap and kept the trans auto?
alright thought let everyone know that i returned the innovative mounts and got my $$$ back. I'm gonna order the mounts from ExplicitSpeedPerformance, but i finished the swap just using the stock mounts for now. Just to let everyone know i'm going to list what i used for this swap.
1)F23A engine
2)h22 auto tranny with torque converter, starter and flexplate
3)i reused stock mounts for now
4)the harness, intake manifold, header, distributor, external coil, top waterneck, hoses, alternaor, powersteering bracket, powersteering pump, and stock radiator were all reused from the stock F22B2 engine.
5)ecu was a f22b1 ecu from a 96 accord, i just ran wire from the ECU pin A8 to the Vtec solenoid and used the connector from the A/C compressor which is the exact same connector as the vtec solenoid. I just ran it through the firewall and made a pinhole through the boot that the harness goes through. Which is located right below the front right fusebox in the engine bay.
1)F23A engine
Have not really seen one of those for auto Accord. If you have a good stock one though you can send it into Innovative and they can custom make it for you.
evoalf
Jun 1, 2005 01:34 PM
