h22a1 swap to jdm h22a
just a quick question, i just got a 96 honda prelude with the h22a1 vtec engine the only thing is that it has 144,000 miles, how hard would it be to swap in the jdm h22a? i found this one at hmotorsonline http://www.hmotorsonline.com/shop/sc...age&item=30016 would this be all that i need for the swap?
yess that is all you will need,but you will either have to keep your external coil dist if u have a external, or wire it for internal and 96 i believe is obd2 so you would also need an obd2 to obd1 conversion harness
