Suspension & Brakes Theory, alignment, spring rates....
Last upgrade of the suspension puzzle
Old Jun 23, 2010 | 02:12 PM
95vxtealhatch's Avatar
Icon2 Last upgrade of the suspension puzzle
I own a 95 Civic VX very close to 2150 lbs; I have built this as my daily driver.
-Ground Control Sleeves over Tokico illumina's with Extended tophats
lowered aproximatly 2" from stock height.
_______________Front_______Rear___
Spring Rate_____:380lb/in____250lb/in_
Illumina setting__:__5_________3_____
-New Oem bushings
-Integra Front and rear Sway bars
-16" Rota GT3's rims
-Mfactory Extended lower front ball joints
-Spherical Rear T/A bushings
Im looking to purchase a front and rear swaybar plus bushings. My concerns are purchasing too large of a sway bar that will upset the balance of my car. My vx is really light in the rear, hence the #3 setting on my rear struts. The turn-in is crisp, and reactive; im looking for more rotation through reduced steering effort; My thoughts are installing a bigger rear bar, and slightly larger front. Im interested in suggestions from people who have similar setups, or experience with multiple swaybar setups.
Thanks for chiming in !
Old Jun 23, 2010 | 02:31 PM
spAdam's Avatar
Loved
Community Favorite
Default Re: Last upgrade of the suspension puzzle
Missing some important info here... your alignment settings. If you're just looking to fine tune, this is where you should look first.
Old Jun 23, 2010 | 03:45 PM
Relic1's Avatar
since you didn't state what "-Integra Front and rear Sway bars" is, I'm guessing you mean the typical 24mm Front and 13mm rear.
I had something very similer to what you listed... but with 24mm front and 22mm rear, the car handled great on the street. But once I got to a track day, I changed almost everything.
Old Jun 23, 2010 | 08:50 PM
98civdx's Avatar
Master Detailer
Im runing a 26mm and 13mm, and I am definetly looking for a 22mm or 24mm rear soon.
I have driven several cars, 22mm and 32mm, (very scary in a hard corner)
24mm and 22mm felt pretty good
And recently a 22mm and 24mm, felt good, enough oversteer to make it a handfull but fun
Old Jun 25, 2010 | 10:54 AM
Todd00's Avatar
I said I don't want a title!
If its a daily driver only, then keep what you have. Why do you need a perfect suspension when driving to and from work?
A daily driver suspension, IMO, should do these primary things:
1) Enhance appearance
2) Maintain all OEM functions
3) Have no "odd" effects, such as squeaking/clanking, twitchy handling, etc
4) Make the car feel and handle more sporty, but not approach being brutal on passengers or your kidneys
Honestly, what you have now is fine for a daily. I'd leave everything as-is. Why the hell do you need tons of rotation in a street car anyways? All that is asking for is troubles when you're flying up an off-ramp and the little old lady in front of you decides to stop on the brakes because it's a decreasing radius turn.
And honestly, if you're trying to make a track car, your springrates are waaay too light anyways. And you could use better shocks, too.
Old Jun 25, 2010 | 05:25 PM
THX, i appreciate all of the input. Suspension mods will be limited, because You are right, my suspension is fine for a daily driver. Instead i think i will price some body work and paint. Very appreciative for your insite and wisdom.
chriskory
10
Apr 26, 2014 05:13 PM
b18eric
Aug 12, 2010 08:13 PM
specialized108
56
Jan 25, 2009 02:27 PM
envee
Suspension & Brakes
Apr 17, 2007 09:26 PM
HX_Guy
Feb 5, 2002 07:31 AM
