wtb asap b series clutch aligment tool
im almost done putting my swap together and all i need to do is install the clutch i need a b series clutch aligment tool got cash some one help me out call or text me 4143448269
This is a trick I used every time and it works every time. Get a ratchet with round handle, the end of the handle should fit into the pilot bearing. Then just use the yellow tape and wrap around the handle about an inch from the end until it's the same size as the flywheel. You get the point.
Just use the biggest socket that fits. ****, I've eyeballed it before and had no problems.
When you put the input shaft in you have to wiggle it around anyway to get the teeth to mesh with the disc. After that it's just push and shove.
swpdb16
Sep 24, 2008 08:13 PM
