Ideas on these odd quirks from my 97' Del Sol
Old Jun 23, 2010 | 01:16 PM
delsolluv's Avatar
Icon6 Ideas on these odd quirks from my 97' Del Sol
I bought a 97' Del sol last year (my second one). Usually in the warmer parts of the year/weather, while at a stop (in drive), it idles rough. Dropping down on the RPM meter to almost nothing. Seeming as if its bout to die. It seems to never act up when in colder weather (obviously due to a high idle in cold weather). Is there a way to fix this? Something to turn the idle up? By the way it is an automatic (booooooooooooooo, I know, lol).
My other question is...
When I bought this Del Sol it seemed that when it shifts into all the gears, it would shift kinda hard. I had a 93' a couple years ago and never remembered the shifting to be so hard. Did Honda change anything between the 93 an 97? The hard shifting doesn't seem to hurt to car, and it's not so hard the it hurts the neck. But it just seems a little more rough. Is this normal for a 97 Del Sol? Again this is an auto Del Sol.
Thanks for any responses!
Old Jun 23, 2010 | 02:24 PM
Gunmetal_B20_Hatch's Avatar
Default Re: Ideas on these odd quirks from my 97' Del Sol
To start with the low idle, I would recommend removing the throttle body and cleaning it well along with the IACV on the back of the intake manifold.
Old Jun 23, 2010 | 02:46 PM
Red_Army's Avatar
as far hard shifting do you still do tranny flushes and so on?
Old Jun 23, 2010 | 03:00 PM
You can try a flush, but dont expect it to work wonders...
Dont worry about changing the trans filter either... Its inside the tranny.
Old Jun 23, 2010 | 03:26 PM
delsolluv's Avatar
I haven't done a tranny flush yet since owning it as of last July.
Old Jun 23, 2010 | 03:28 PM
delsolluv's Avatar
Thanks, I'm far from a mechanic, so I'd have to bring it into a shop to do it.
Old Jun 23, 2010 | 03:33 PM
delsolluv's Avatar
Before I bought it my cousin (who is fairly mechanical), said it seemed normal when shifting and gave me the okay to buy it. But from having a 93' del sol a couple years before, its seemed a little too different when shifting... hmmmmm. I dunno, just figured Honda made mods to it in later years to have a little bit tighter shift.
Old Jun 23, 2010 | 04:04 PM
Former User's Avatar
How old are the plugs, wires, cap, and rotor?
Try draining the ATF and replacing with Honda or Honda-recommended ATF. Do this drain and refill 2-3 times with a short drive in between.
Old Jun 23, 2010 | 04:18 PM
delsolluv's Avatar
I believe my cousin did the plugs and wires for sure. Not sure what the cap and rotor is, (I'm not mechanically inclined what so ever, so I'd have to get it done by a shop.) I'm guessing ATF is automatic transmission fluid. I haven't changed the tranny fluid since owning it last year.
sucks not being mechanically inclined, lol
Old Jun 23, 2010 | 04:29 PM
The distributor cap is where the spark plug wires run to. Remove 3 bolts to get the cap off. Inspect the contact points inside the cap and on the edge of the rotor.
Draining the ATF is simple -- remove drain bolt. Buy a plastic container from Walmart to collect the old oil and then refill to the Full mark.
Old Jun 23, 2010 | 05:22 PM
delsolluv's Avatar
Ah, I'm guessing just doing what the top figure suggests. Is the drainage bolt hard to find? Then once done draining, take apart with the three bolts, look at the rotor contact points making sure they....look fine? Then put back together and put ATF OIL in it? Any other things need to do?
Old Jun 23, 2010 | 05:41 PM
Old Jun 23, 2010 | 06:01 PM
delsolluv's Avatar
I'm afraid I'd mess up my car if I took that part apart in the diagram. The most I've done on my car is an oil change, headlight replacement, stuff like that, (i'm such a rookie to this type of stuff.). I may be able to master the ATF change. Think the change will help it shift better? Can I get Honda ATF at autozone or would I have to go to a Honda dealer?
Old Jun 23, 2010 | 07:04 PM
Honda dealer.
odoscar25
Jul 31, 2012 05:51 AM
odoscar25
Jul 29, 2012 10:00 PM
SteveDGK
Dec 6, 2011 03:15 PM
