AC line question B series swap.
Old Jun 23, 2010 | 10:59 AM
bigchris2000's Avatar
Default AC line question B series swap.
I am putting ac back in my 91 hatch with a B series engine. everything fits fine, but my rubber lines off the compressor are about 2 inches away from my header. I know the lines are pretty close on a stock car, but should I buy some type of heat wrap to go around the hoses for added protection? Thanks for any help.
Old Jun 23, 2010 | 03:48 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: AC line question B series swap.
On my friends car,
shortly after we swapped it,the a/c hose melted and burst..
If memory serves me,He went to a place that makes hoses
and had one made about 1 foot longer than stock out of flexible
a/c hose..
The extra length allowed the hose to be routed around the fan shroud
and away from the heat source.
Old Jun 24, 2010 | 07:06 AM
Jaime 91SiB18's Avatar
I'm running Innovative Mounts and their A/C bracket. All I did was heat wrap my lines, but I'm running the stock manifold with heat sheild as well.
Old Jun 24, 2010 | 09:16 AM
Thanks for the info. What are you guys that have a header on a B swap using, if anything? I know someone on this forum has to have a header on their car with A/C.
I am thinking about wrapping the lines using some Thermo Tec heat tape that is for wires or hoses. Any input on this?
Old Jun 24, 2010 | 09:23 AM
Originally Posted by 88DXCRX
On my friends car,
a/c hose..
Thanks for the info. I will give the heat wrap a try first, and if it turns out to be a problem I will look into doing what your friend did.
Old Jun 24, 2010 | 03:11 PM
zrickety's Avatar
wrap might help but it will not save you...i had a hose melt and burst after it was wrapped.
your best bet is to secure the hose to the radiator with tie wraps. i also used pieces of old radiator hose on places where it might rub. holding up so far!
a hydraulics shop is your friend if you need hoses repaired or modified. i can take pics of my setup if you want.
Old Jun 24, 2010 | 04:05 PM
Thanks. Please post some pics.
SanfordBuilt
10
May 23, 2020 02:44 PM
bigchris2000
May 1, 2010 09:55 AM
Speedra500
Jul 8, 2007 02:46 PM
fitbmx86
May 6, 2007 11:48 PM
slow-n-low
Aug 7, 2003 09:11 PM
