Only the fan turns on when trying to start..
Old Jun 23, 2010 | 10:06 AM
Adamvanxxx's Avatar
Default Only the fan turns on when trying to start..
To start the car is a 96 CX with a Y7 in it, it is also OBD1.
So when I was driving home my temp gauge was bouncing from hot to cold, I turned my heat up and pulled over. Check all fluids, fuses, reset the ECU, everything was fine. But now when I try to start it only the fan comes on, no fuel or starter. I dont think its a battery issue because everything runs but that.
If you could help at all it'd be great
Old Jun 23, 2010 | 10:08 AM
JDM_SOHC's Avatar
Default Re: Only the fan turns on when trying to start..
Was your fan hotwired..?? Sound's like an electrical problem...
Old Jun 23, 2010 | 10:17 AM
Adamvanxxx's Avatar
No the fan is not hot wired, I just have no idea where to start.
Old Jun 23, 2010 | 10:21 AM
JDM_SOHC's Avatar
Smell coolant at all..??
Old Jun 23, 2010 | 10:31 AM
Adamvanxxx's Avatar
No coolent levels were fine and both hoses where hot so I do not think the thermo is bad.
Old Jun 23, 2010 | 10:47 AM
JDM_SOHC's Avatar
hmmm, sounds like a short to me...
redline09
Aug 25, 2010 05:56 AM
f1fever
Apr 20, 2008 03:34 PM
londonsupra
Feb 13, 2007 08:34 AM
7808
Jan 2, 2006 11:47 PM
DrewDown
Aug 23, 2005 12:56 PM
