Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Little on rear sway bar
Old Jun 23, 2010 | 08:32 AM
So krazieY's Avatar
Default Little on rear sway bar
I was installing my Spring in the rear, i had to release tension on my sway bar links. I lift it a little to high and it bent a little. Will the little bent cause any problem, like abnormal tire wear? It still handles fine.
Old Jun 23, 2010 | 01:34 PM
So krazieY's Avatar
Default Re: Little on rear sway bar
BUmp for help?
Old Jun 23, 2010 | 03:55 PM
K5^'s Avatar
K5^
Brand New
How bad of a bend is it? Take some pictures and post them up.
Old Jun 23, 2010 | 04:22 PM
So krazieY's Avatar
Its just a little bent, hardly noticeable. Just wondering will it make my abnormal tire wear?
Old Jun 23, 2010 | 09:11 PM
K5^'s Avatar
K5^
Brand New
Do you mean a nick on the surface of the bar? I'm trying to gauge the state your bar is in and you're not giving much to work with.
Anyways, a small nick on the paint isn't going to hurt anything, especially tire wear.
Old Jun 24, 2010 | 05:41 AM
SafetyMan's Avatar
I agree small paint damge no problem. if you bent the actuall bar could cause problems depending on the degree of the bend
Old Jun 24, 2010 | 09:27 AM
So krazieY's Avatar
It clearly an bent(not noticeable but still a bent), It bent up little bit. I would post pic, but not at home until Sunday.
jit01
Feb 22, 2008 11:02 PM
Repin da R18
Jul 10, 2007 08:47 AM
TegoDC5
Suspension & Brakes
14
Sep 13, 2005 08:45 AM
tthomass
Suspension & Brakes
14
Apr 11, 2005 01:00 AM
celica73
16
May 15, 2002 02:42 PM
