crx b18 swap harness problems
i bought an ls engine out of 91 integra jdm online, and like all jdm engines it came with the harness all cut out and i m using my crx harness everything fits all good except the injectors my harness was modififed by the first owner but was never put in cuz i bought the shell, and i wanna know if there is a place where i can buy harness converted or i can just cut the end of the engine harness and swap to the car harness it sounds complicated
first off, you can search. this is covered/asked almost everyday.
second off we need info on your car:
is the crx a DX, HF or Si model?
if its a DX then you will need to do an mpfi conversion. if its a HF or Si, then you need to get a complete stock harness. do not use the one from the motor, use the stock harness that belongs on your car.
i believe that the car is an hf because it doesnt specify in the tittle neither in the car since the first owner was building it... and the harness does have the mpfi conversion but what i dont get is why it doesnt fit the injectors.. is it because the engine is japanese?????
b18_crx
Oct 19, 2008 10:23 PM
exist12
Oct 26, 2007 08:19 AM
