Suspension & Brakes Theory, alignment, spring rates....
sway bar compatibilities...
Old Jun 23, 2010 | 12:48 AM
heartpownda17's Avatar
Default sway bar compatibilities...
okay.. i have a 97 ek..
i have a R Crew sub frame brace..and function 7 LCA's..
what kind of sway bars can i use? i had a "CTR" sway bar on it with Blox adj endlinks but i think the sway bar was a fake one..because when i had it mounted the endlinks were not 90 degrees vertical..they were going in like this / \ ...is that right? i can take some pictures..i took the sway bar off because it was making a shitload of noises...it seemed as if the sway bar was not long enough??
Old Jun 23, 2010 | 07:44 PM
98civdx's Avatar
Master Detailer
Default Re: sway bar compatibilities...
Yes, you can use ctr, the noise was from the endlinks, I have them and they are very noisy..
They should be striaght up and down.
Did you ever try putting them in different holes in the lca?
Old Jun 23, 2010 | 09:19 PM
yea i used them in different holes in the LCA but its still not a up and down 90 degree angle...
Old Jun 24, 2010 | 12:39 PM
98civdx's Avatar
Master Detailer
Im starting to think it's just endlinks, I dont think my rears and at 90, My fronts and damn close, also runing adjustables in front.
JDMCRX
Suspension & Brakes
Jun 14, 2008 03:53 PM
remoer
Suspension & Brakes
May 20, 2008 04:45 PM
Midori Green
Feb 12, 2008 11:39 AM
