Peakboost turbo kit complete!!!!
Old Jun 22, 2010 | 06:53 PM
JdMhEaD's Avatar
Default Peakboost turbo kit complete!!!!
I am selling my Peakboost turbo kit. I received it in a trade around October of 2009. The guy i got it from had put it on his car for break in miles and the motor ended up blowing before the car was tuned. The kit came with a GT35R turbo and i traded it for the current turbo the kit has. I installed the kit on my car around November and the car went to the dyno in March. On a 81.5mm stock sleeve motor i made 531hp with 114octane at 23psi before #4 sleeve cracked just barely. I then bought a 84.5mm sleeved bottom end and made 553hp with 21psi. At 23psi i believe it saw 570ish. Then we went to 29psi and could not get any solid numbers past 7000rpm because we were spinning on the dyno. At 7000rpm we saw 570ish. With my times and MPH (141mph) i was running it looks to be right at 600hp maybe a little more.
On to the kit.
Includes
- Peakboost topmount manifold T3 flange/ Single 44 flange
- Garrett T3/T67 .63 a/r powder coated hotside .70a/r cold side
- Tial 44mm Wastegate silver with dump tube
- Tial 50mm BOV
- Garrett intercooler (core measures 24x8x35, with endtanks its 30.25 long)
- Peakboost charge pipe kit (2.5inch)
- 4 bolt to vband downpipe adapter
- 3 to 4 inch downpipe (has been cut and turned about 80* for side exit exhaust)
- 4inch side exit slash cut pipe ( vband connection)
- Bosch 1000cc Injectors (peak and hold)
- Boost solenoid with extension wire (has 4 pin OEM o2 sensor connectors)
- oil feed line (NO RETURN LINE INCLUDED)
The only bad part about the whole kit is the turbo has a few chips on the compressor wheel from a wire getting sucked in. The car was tuned with the new motor with the wheel damaged! So it built 29psi fine on the dyno and saw 30+ psi on the track and did not see any issues with it.
I am selling this all to upgrade to bigger stuff all around. There are NO PROBLEMS with this kit!!! Excellent quality and very reliable.
I have all receipts for the kit also!
Price is $3500
You can call or text message me at 205-401-1433
Trades welcomed. Cars, trucks, dirt bikes, sport quads, uhh...throw me some offers.
Heres some pics of the kit installed on my car
Showing intercooler fitment
Heres pictures of exhaust under the car
out the bumper
Old Jun 22, 2010 | 09:03 PM
550whpcivic's Avatar
Default Re: Peakboost turbo kit complete!!!!
If you start to part out lmk I want the manifold
Old Jun 22, 2010 | 09:28 PM
Ron Burgandy's Avatar
HAWT SEX
bump for you
Old Jun 23, 2010 | 04:32 AM
JdMhEaD's Avatar
Bump!
Old Jun 24, 2010 | 08:26 PM
JdMhEaD's Avatar
bump...need to sell
Old Jun 25, 2010 | 01:02 AM
jonesEK's Avatar
bump that exhuast is fawkin lovely
Old Jun 25, 2010 | 07:02 AM
Russyo's Avatar
WOW! Very nice setup, and super clean engine bay! BUMP GLWS.
Old Jun 27, 2010 | 03:39 PM
JdMhEaD's Avatar
Put the kit back on the car yesterday to go run a local race and everything worked flawlessly!!!! clutch started slipping at 24psi but still managed a 7.27 @108mph in the 8th with 2nd gear not quite shifting right. I ended up taking home the win in the footbrake race!
Im still interested in trades for a dirt bike. (250f, or 125 2 stroke + cash), OR t4 manifold, turbo, etc and cash.
Old Sep 18, 2010 | 09:49 AM
Do-Work's Avatar
ill trade you for my setup
I have a real RMF drag header with a 3inch mega phone collector-mint
Toda itbs with a custom top mount fuel fed with bosch 550cc injectors and vacuum box-for b16/b17/type-r heads
Endyn 84.5mm 12.5.3comp roller waves pistons
Skunk2 Pro3 cams for b-series etc
Old Sep 20, 2010 | 12:15 PM
JdMhEaD's Avatar
will part out....
went 10.6@139 the other night....
Old Sep 20, 2010 | 01:25 PM
habib's Avatar
how much for the exhaust shipped to 71111
Old Sep 21, 2010 | 05:47 AM
JdMhEaD's Avatar
Downpipe and side exit sold
Old Sep 21, 2010 | 05:59 AM
Dc4LsTeG's Avatar
EK9
bump i wish
Old Sep 21, 2010 | 08:13 PM
Do-Work's Avatar
Old Sep 22, 2010 | 08:34 AM
JdMhEaD's Avatar
I pm'd you back and said no thanks.
Old Sep 22, 2010 | 11:57 PM
em1effekt's Avatar
how much for the top mount
Old Sep 23, 2010 | 12:48 PM
JdMhEaD's Avatar
replied in PM
My JDM EJ8
Aug 28, 2009 05:05 PM
DaYZeD.1
Nov 11, 2008 12:02 AM
BEEYOND
Jan 31, 2007 11:19 AM
toad2039
Nov 20, 2005 10:50 AM
