ideling and miss fire problem
Old Jun 22, 2010 | 01:42 PM
jdm_xsi206's Avatar
Default ideling and miss fire problem
ok so i have a four door civic and its ideling really low. My car never had a map sensor on the tb until i swaped out the motor and put in a mini me swap. Also my car is miss firing. I was told to change the spark plugs. Cuz i changed the timing belt at a shop. Anyone have any idea whats wrong wit my car?
Old Jun 22, 2010 | 03:16 PM
airric's Avatar
Default Re: ideling and miss fire problem
when you put the plug wires back on are you sure you put them on in the right order? also... When you changed the spark plugs are you sure you gapped them right? And are you throwing any codes?
Old Jun 22, 2010 | 07:39 PM
jdm_xsi206's Avatar
the wires are put on right. I havent changed the spark plugs yet. I jus got the timingbelt changed. The code would come on once in awhile and when i turn off the car and turn it back on i goes away. I was told i jus need to change the map sensor. Cuz my old map sensor was not on the tb.
Old Jun 22, 2010 | 07:47 PM
airric's Avatar
Yeah, try changing the map and see what happens.
Old Jun 22, 2010 | 07:55 PM
jdm_xsi206's Avatar
i would but map sensors cost to much. So i have to look around junk yards or online
ShortyzKustomz
10
Jul 2, 2008 04:36 AM
EJ8 GSR-T
Honda S2000
Jul 18, 2007 06:44 PM
em14ever
Jun 27, 2007 04:39 PM
MilanoCivic97
Mar 9, 2007 10:12 PM
filetofit
Jul 9, 2002 09:02 AM
