OBD 1 ECU P28 P72 P30 P75 VTEC ECU
Old Jun 22, 2010 | 11:51 AM
HondaRacer2k's Avatar
Default OBD 1 ECU P28 P72 P30 P75 VTEC ECU
I have a PR4 ecu converted to P28 / P72 / P30 specifications. It will run a VTEC motor just like a P28, P72, or P30 ECU. It can also run non-vtec motors just like a P06, PR4 or P75. I will include a CD with tuning and datalogging software. It currently has vtec on and set for 4500 RPM's, and also a 2 step launch control programmed into it and set for 5000 RPM's. It can be changed to whatever you want it to be. You have the option of either running vtec or not which comes in Handy. I had a LS turbo which I converted to LSVTEC Turbo. It has a chrome chip which is preprogrammed for 6lbs of boost. I was going to use it for my LSvtec turbo set-up, but got carried away with the swap, so I'm running a S300 ecu.
Chipped ECU- $150 or BO
I also have a GM 3 bar map sensor and a 19T LS, GSR, ITR waterpump from the factory. Both unopened that I'm trying to get rid of. Waterpump comes with pump, gasket and allignment pins
MAP Sensor- $50
Waterpump- $60 or BO
Let me know if you have any more questions
hondakrazy
Engine Management and Tuning
May 22, 2010 07:26 AM
ganjasnack
Jun 12, 2007 10:34 AM
kihun_cha
Dec 8, 2005 10:38 PM
streetlvlhatch
Mar 17, 2004 05:50 PM
