Any Other Non EFI Based Honda Engines Larger than 1.8L
Old Sep 14, 2002 | 06:55 AM
Merlin1068's Avatar
Default Any Other Non EFI Based Honda Engines Larger than 1.8L
I think the 1.8L Dual Carb from my 85 Prelude works just fine, needs a better clutch but still holds its own.
Are there any other Non EFI engines from Honda that will Generate more HP?
I am also lookin around for other possible engines to build on while racing the one I have now. I want to stay Non NOS and Non Turbo.
Old Sep 14, 2002 | 11:28 AM
killerprelude86's Avatar
Default Re: Any Other Non EFI Based Honda Engines Larger than 1.8L (Merlin1068)
i <U>think</U> there is an accord with a 2.0 carb
Old Sep 14, 2002 | 12:42 PM
Missingsohc's Avatar
If you want a hybrid take the 87 prelude 2.0 Si block and rebuild it to max over bore then it's a 2.1XX and slap the ET-2 head or the A18A2 head They will bolt up. But then your gonna need the si tranny (shorter gears) and a set of webers to keep up with all that combustion. S&S header would help too
[Modified by JDMET-2, 4:46 PM 9/14/2002]
Old Sep 15, 2002 | 05:40 AM
4wsB21a's Avatar
New User
88-91 prelude s models have a 2.0 dual sidedraft carb motor in them. they put out more hp than the 85-87. they probably bolt up somewhat similar too. i haven't done much research on those motors.
chihuahuamanx
Dec 7, 2004 12:29 PM
