Lug?Stud?Adapter? Confused?_? help..
hey guys i have the 96 spec ITR rim 114.3
i own a Civic Hatch CX 95 which is you know 4x100
i plan on putting these rims on to that car with an 4x100 to 4x114.3 adapter
which has a 25mm Spacing and the ITR is +50 Offset which will make it +25 offset (do they make adapters with less spacing?)
what im confused about is do i need an extended lug/Stud? or can i use my stock ones that came with my car (OEM)?
will i need to fender roll? i plan on using the OEM spec Tires for the ITR rim which is 195/50/R15.
anyone has a picture of a EG hatch with ITR rims on a 25mm adapter?
thanks for your help
Boosted_Coupe
Oct 22, 2009 03:37 PM
<3 you.
