turn your DPFI EF into a CRX HF MPG machine
Old Jun 22, 2010 | 05:24 AM
red civic standard's Avatar
Default turn your DPFI EF into a CRX HF MPG machine
I have all of the necessary items to convert your 88-91 Honda Civic/CRX DPFI engineto run like a MPFI CRX HF engine. This will require you to do a DPFI to MPFI conversion. Here are two good writeups.
http://hondaswap.com/swap-articles/d...writeup-49557/
http://www.zcspeed.com/DXZCwiring.pdf
Here is what I am selling:
--Complete CRX HF intake manifold/throttle body with injectors
--Complete CRX HF intake (so tiny)
--Complete CRX HF wiring harness (you will need the plugs to do the DPFI to MPFI conversion) including injector resistor box
--MPFI distributor and spark plug wires
--CRX HF pm8 ecu
--CRX HF throttle cable
This swap will not get you CRX HF MPG as there are several other factors to consider (engine head, transmission, axles, weight) but it will certainly improve mileage over the stock DPFI.
$290 shipped through United States Postal Service Priority Mail. Send me a private message or email at luke.wilcox@gmail.com
Old Jun 23, 2010 | 07:26 AM
Default Re: turn your DPFI EF into a CRX HF MPG machine
bump
Old Jun 24, 2010 | 04:23 AM
up
Old Apr 17, 2011 | 09:30 AM
deadhead42020's Avatar
is this still up? would you wanna part the harness out?
jdmcrxvtec
Paint and Body
Feb 20, 2008 08:16 AM
BOS#20
Jun 8, 2006 08:21 AM
