MD: Toyota 5sfe Turbo Kit - Near Complete (Camry, Celica, MR2, etc)
Old Jun 22, 2010 | 04:59 AM
Purple-skunk's Avatar
Default MD: Toyota 5sfe Turbo Kit - Near Complete (Camry, Celica, MR2, etc)
For sale is a near complete Turbo Kit for the 5sfe Toyota motors / engines (with instructions) found in the following vehicles (and others):
Camry 92-97
Celica 90-99
Solora 98-01
MR2 (n/a) 90-95
+ others
This kit was used for a very short period on a 91 Toyota MR2, and removed when the car was sold. The parts listed are a tried and proven combination for reliably boosting the 5sfe motor. It will allow the 5sfe to be boosted to approx 8psi, and give a 50 - 60 HP increase over stock. All parts bolted directly to the 5sfe on a 91 MR2.
The following items are included in the kit and were sourced from the 3sgte Toyota MR2 (unless otherwise specified):
3sgte Exhaust Manifold
3sgte CT26 Turbo (may need rebuild)
3sgte stock DP
3sgte stock mid pipe
3sgte stock muffler
3sgte oil return line
3sgte MAP sensor
3sgte turbo to intercooler "hot pipe"
3sgte BOV
Spark plugs
The following parts were custom made and/or used for this application:
CT26 oil line with welded 4AN male oil feed
Nissport 1/8(M) BSPT to 3 port 1/8 NPT (F) adapter
Earls 1/8 NPT(M) to 4AN (F) adapter
Earls 4AN (F) to 4AN(F) braided hose
315cc injectors (86-89 Supra)
Intercooler to throttle body pipe pipe
The following are miscellaneous items that will also be included:
Water lines
Boost gauge
Exhaust maifold gasket
Turbo Gasket set
Various clamps and hoses
The following items will be needed to complete the kit (depending on application) and are NOT included in this sale:
Intercooler
Intercooler pipes
Oil pan (can use one from 3sgte or custom weld bung)
Custom CT26 intake
Other optional items NOT included:
Boost controller
MSD BTM
Please note: the kit was used and worked on a 91 MR2. All parts listed work (although the CT26 could use a rebuild). To find out how much this kit can increase the performance of the 5sfe motor, do a google search on "5sfe Turbo" or "5sfTe" (note the "T" in the text). Instructions as to how to perform the install can be found on the web, but will also be included with the kit. Also note: Only the items listed in the above description are included. Some items shown in the pic may NOT be included, as the pics were taken BEFORE the parts were installed.
Feel free to email with questions. Serious inquiries only please. Please..LOCAL Pickup (or delivery) Only.
Pictures in ad below
http://frederick.craigslist.org/pts/1776618995.html
PM me with any questions you have
Thanks!!
Flamenco-T
Jul 26, 2010 07:34 PM
Purple-skunk
Mid-Atlantic (Sales)
Jun 22, 2010 04:58 AM
Flamenco-T
Aug 21, 2008 07:34 AM
90civichb
Oct 28, 2004 12:26 PM
ItzTw
May 22, 2003 04:37 PM
