90 crx cluster problem
Ok guys I just finish swapping in an ls engine into my 90 crx si shell and all. I had to swap in a front body harness from my old 89 crx si. Once done, the car started up right away but the thing that sucks are gauges. For some reason the rpms, speedo, temp and fuel gauges do not work. Only the battery sign comes up normally and the brake indicator when i put the parkin brake on. Also no light comes up, as in the dimmer or w.e its call to see the numbers in night lol. Can all this be caused by a blown fuse? or having to use a 89 crx si body harness into the 90 crx si shell with slight different cluster? When i first started the car the rpms moved normally for a couple of seconds until it just stopped working with the car idling.
waspcrx19
Jun 24, 2010 05:33 PM
CRXB18C1_ALL MOTOR
Jul 21, 2009 07:34 AM
