MI Fully Customized 1992 Acura Integra
Up for sale is my 1992 Acura Integra GS, This car has been in many newspapers, won trophies, been in modifed magazine and much more. I had my fun with it but its time to move on and progress with my other projects.
Here is the details:
Exterior:
JDP Engineering Front Lip
Brand New DEPO clear corner lights & bumper lights
Brand New DEPO OEM Headlights & Fog Lights
shaved emblems , trunk keyhole and handle, rear wiper
Xenonvisions 6000K HID kit with ballasts and wiring hidden
OEM Acura moon roof visor
OEM Acura mudflaps
Red Vision Motorworks rear tow hook
Paint:
Custom mixed Cativa Blue Pearl paint with silver metalliac flake
the airbrushing was done by Trendsetters Custom Airbrushing. Many are real
world photos from Iraq. This car is a tribute to the American troops who
faught for our country.
Interior:
Genie Rock Candy II shift ****
270MM flat Brodway mirror
Blue ACC Mats Carpet
Black/Red Checkered Front and Rear Door Panels
Blue suede headliner
Custom American Flag upholstery by Audio Tek LLC
Autometer digital cobalt - volt, water temp, fuel pressure and oil pressure gauges.
suede ITR shift and ebrake boots
I am sure I am missing more
Rims & Tires:
15” Rota J-mags (Royal Lip Red) with brand new general tire 205/55/15 tires
Performance/Motor which has over $10,000 worth of parts and was built professionally by C-Tech Performance in Wyoming,MI ($6,500 in labor). Ran a 14.3 at US131. Motor has 10,000 miles on it currently. Has 94-01 Integra ECU with custom basemap and tune cost over $800
The Head:
(Fully cleaned, gasket match ported intake, gasket match ported
exhaust/polished, polished combustion chambers, gasket surfaces cleaned)
Super tech valves, springs, retainers & valve seals
valve clearances checked
head milled .030
5 angle valve job
Crower Stage 2 403 camshafts
Crower polished camgears
ARP Head & Main studs
Gates Racing timing and supertine belt
Kamikaze Black 4-1 Header with 2.5" downpipe
Thermotec Cool-Air Tube Heat Shield Wrapped Intake
K&N Short Ram Intake
MSD Extreme Distributor Cap 82922,Rotor 8092,Wire Set Extreme 8.5MM Wires 35329
Golden Eagle Fuel Rail (Blue)
Fuel Inlet Hose converted to Earls Stainless Steel Hose ith -6AN fittings, Earls Plumbing Inline Filter and More
Brand New Rebuile OEM RC Injectors that were balanced,blueprinted & ultrasonic cleaned
Skunk2 intake manifold
All Cometic Gaskets including Headgasket in the head
The Block:
Mahle 10.5 Pistons, rings, & pins
Bored over .25 MM
BILLET CROWERODS ACURA INTEGRA 1.8
Moroso Oil Pan
ACL Race main, rod and thrust bearings
Cometic Full Gasket kit C4388 & Head gasket C4238-030
ARP rod bolts
Fresh Hone
Block Completely hand cleaned and Black silcone coated
Ralco RZ Single Belt Conversion Crank Pulley (Alternator only)
Aasco Lightweight Flywheel (8lb)
Exedy Stage 3 Clutch & Pressure Plate
Raxles Custom All Motor/Autocross SCCA Axles
Full 2.5" Stainless steel exhaust
Vibrant Performance Muffler
LSD YS1 JDM XSi Trans
Fidanza Short Throw Shifter
Energy Suspension shifter bushings in shifter and stabalizer
And More
Oil changed every 3K with Royal Purple Break-In Oil and Fram or K&N Filters
Engine Dress Up:
Skunk2 oil cap,
Army Resorvoir Covers,
Skunk2 radiator cap,
B20 Silver Powdercoated valvecover
multi-color (red,white,blue) fully shaved engine bay done with welds and metal no bondo.
.50 Cal custom dip stick
Hidden cruise control in wiper cowl
Full wire tuck
Cooling:
Gates Racing radiators hoses (Blue)
Ron Davis Racing aluminum radiator & overflow tank
Buddyclub fan switch
SPAL fans
Duralast low temp gold thermostat
Suspension/Brakes:
Brembo Blank Rotors
Axxis Performance HPS Ceramic Brake Pads
Goodridge S.S. Brake Lines (Front & Rear)
Tein S. Tech Lowering Springs
KYB GR2 Struts
ASR Swaybar Kits
ASR Subframe brace
SPC Rear Upper Control Arms/Camber Kit
Adjustable front upper control arms
Megan Racing rear lower control arms
Greddy front strut tower brace
Z-speed rear strut tower brace
Car Audio/Video:
Jensen VM9512 In-dash DVD/CD/Radio
Kicker ZX1500.1 Amp
Kicker CVR2 12" subwoofers
Kicker 4 channel componet amp
Kicker 5.25" speakers in doors and hatch
All Kicker Wiring
Custom Fiberglass dual enclosure
Custom amp floor
Custom battery box with odyessy battery
Battery cut off hidden and Battery jump terminal underhood
Cobra Alarm
I am sure I am missing some things, I am taking offers. I am willing to trade partially for a daily driver car and cash. Let me know what you got and we can deal
Exterior:
OEM Acura mudflaps
Paint:
Interior:
Rims & Tires:
The Head:
head milled .030
5 angle valve job
The Block:
Bored over .25 MM
Moroso Oil Pan
ARP rod bolts
Fresh Hone
And More
Engine Dress Up:
Skunk2 oil cap,
Full wire tuck
Cooling:
SPAL fans
Suspension/Brakes:
Brembo Blank Rotors
KYB GR2 Struts
ASR Swaybar Kits
ASR Subframe brace
Car Audio/Video:
Kicker ZX1500.1 Amp
All Kicker Wiring
Custom amp floor
Cobra Alarm
Wrath of VTEC
Nov 22, 2014 10:06 AM
justhatched231
Jul 23, 2010 05:57 AM
