blower question... ef problem?
Old Jun 21, 2010 | 05:22 PM
graveltravel2's Avatar
Default blower question... ef problem?
ok... quick question here.....
i got my a/c working!! yay!!!
but theres a problem....
and i dont know if i ever noticed it til today, but.............
my car has a crx dash conversion.
when i turn up the air full blast, it seems like its on the 1st position on the climate control guage.even going from position 1 to 4 theres a bit of difference.
now, i hear the blower motor blowing full blast..... but, it just blows weak out of the vents. are ef's like this or do i have a problem?
i dont know how it was before i put the dash in ,or after because i never used the vents. i only used the defroster.
well, i went digging around and screwed with alot of bolts. found a mouse nest in the dash....
blows the same...
messed with the box thingy behind the glove box...
blows the same...
is this normal, or is there a problem?
are there any "cabin filters", or anything that could get clogged up with debris in the air system?
Old Jun 22, 2010 | 02:33 PM
Default Re: blower question... ef problem?
wow! no answers yet???
Old Jun 22, 2010 | 03:16 PM
B16-CRX's Avatar
maybe you have a bad blower motor resistor
Old Jun 22, 2010 | 03:27 PM
what are the symptoms?
if it was a resistor... wouldnt it not work at all?
where is it located?
Old Jun 22, 2010 | 04:32 PM
1990hondacrx's Avatar
located on top of the blower motor 2 screw's and a plug mine was bad and it would only blow on 1 and 4 it is just some wires basically in it and in the box to help keep them cool they can get leaves and trash in it and cause them to burn up
Old Jun 23, 2010 | 06:16 AM
well, i checked the resistor,... it looked fine, but i ordered one from honda today...
i also cleaned out that box beside the blower...
i pulled the blower down just enough to get a airline in there and blow some **** out.
a bunch of leaves came out but nothing major.
and it seemed to help it out just a hair.
next up resistor, then blower.
Proper
Audio / Security / Video
May 31, 2010 10:54 AM
BlackYoshi
Jul 11, 2007 06:46 AM
ED6JDM
Oct 15, 2006 06:45 PM
h22chilton
13
Mar 23, 2006 10:36 AM
boostinb18
Dec 24, 2002 12:03 PM
