b18b serious issues!
Old Jun 21, 2010 | 02:14 PM
b20hatchek's Avatar
Icon6 b18b serious issues!
droped in a b18b and its going crazy, one minute it runs as if it has a misfire and the next alot of surges and bogging down and dies on me, anyone?
Old Jun 21, 2010 | 02:23 PM
freeagent's Avatar
Default Re: b18b serious issues!
check if the plpug wires are correct, it happins and does the same thing mentioned,
it should be on the dizzy
...3..4 top two
..1..2 bottom two
and one being the cylinder closet to the timing belt
Old Jun 21, 2010 | 02:26 PM
b20hatchek's Avatar
yeah i checked those and they're correct, anything else?
Old Jun 21, 2010 | 02:28 PM
D16SiHatch's Avatar
check engine light on? all vacuum lines hooked up?
Old Jun 21, 2010 | 02:29 PM
b20hatchek's Avatar
no cel's and no vacum leaks
Old Jun 21, 2010 | 02:32 PM
D16SiHatch's Avatar
are you sure the cel is functional?
what ecu and distributor are you using?
Old Jun 21, 2010 | 02:34 PM
b20hatchek's Avatar
yeah cause i had cel's on my b20b because of the o2 and now i dont have any, tha distributer is the b18 and ive tried the b20 and it got worse so i put the bb18 back on and didnt change back, and im running a pr4 ecu
Old Jun 21, 2010 | 02:39 PM
b20hatchek's Avatar
would it make you guys happy if i run out and swap the injectors
Old Jun 21, 2010 | 03:32 PM
raidacaipo's Avatar
switch sensor plugs. TPS and MAPS sensor. They both look the same and those are the symptoms of the sensor plugs being switched.
Old Jun 21, 2010 | 03:45 PM
J-oulton's Avatar
had this same problem on a prelude last week, spark plugs, wires, distributor, they were all ****ed, fixed those and the miss fire was gone, but we still had the problem of it bogging out and dieing? thought of a bunch of things sounded like the exhaust was plugged or the vaccumm messed, but all that has been mentioned, good luck.
Old Jun 21, 2010 | 04:14 PM
b20hatchek's Avatar
alright i'll get out there and swap some things out, if anybody thinks of anything else Lmk
Old Jun 21, 2010 | 08:31 PM
tlarimer's Avatar
I had similar problems when I was running the PR4, swapped in a P75 and it went away, couldn't explain it, but it worked for me.
Old Jun 21, 2010 | 08:45 PM
slowhatchcali's Avatar
same here, i let my friend borrow my p75 for ref and i completely forgot i had his pr4 and went to drive my car and it ran like crap.. i would bog and idle real low and shut off on its own, i switched the ecu back to my original one and it worked flawless since...
Old Jun 21, 2010 | 09:28 PM
solb20's Avatar
the reason why is because the pr4 has a knock sensor located at a diffrent pinning then the p72 so its kinda like if u had no knock sensor connected so its just better to run the p72
Old Jun 22, 2010 | 11:09 AM
D16SiHatch's Avatar
pr4 does not have a knock input and neither does an obd1 p75. hell i'm not sure if even the obd2 p75 ls had a knock sensor.
really no reason a p75 should work any better than a pr4.
Old Jun 22, 2010 | 08:37 PM
tlarimer's Avatar
PR4 is for the b18a1, p75 is for b18b1. Like I said, can't explain it, but it solved my problems 100%.
Pr4 and obd1 p75 ecu's do not look for a knock sensor, since the corresponding engines did not come with a knock sensor, period!!!
Old Jun 22, 2010 | 08:47 PM
tlarimer's Avatar
Your comparing apples to oranges!!!
PR4=b18a1 non-vtec 90-93 obd0/obd1(no knock sensor)
p72=b18c1 vtec 94-up obd1/obd2(has knock sensor)
p75=b18b1 non-vtec 94-up obd1/obd2(no knock sensor on obd1)
Old Jun 23, 2010 | 11:22 AM
b20hatchek's Avatar
well anyways i can't do anymore testing on the car now, either myself fuel pump relay went out or the pump went bad but the the pump won't kick on at all so im probably going to just throw money at this and replace the relay and the pump then back to the issue at hand, thanks you guys
Old Jun 23, 2010 | 02:02 PM
Matt93eg's Avatar
Negative. He is talking about an LS, why would he be better off running a GSR(P72)ECU rather than the LS ECU??
X2. And just for kicks, my P75 runs my LS Flawless also, never ran a PR4 though.
Old Jun 23, 2010 | 03:12 PM
D16SiHatch's Avatar
i just assumed the guy mistyped, maybe not though.
Migs19
Mar 29, 2016 08:53 PM
Homotor
Dec 18, 2007 10:14 AM
tlieu88
Dec 27, 2001 08:51 AM
