a/c problems
Old Jun 21, 2010 | 12:32 PM
seanabekasis's Avatar
Icon2 a/c problems
i have a 91 civic si hatch and my a/c compressor isnt getting any power. when i take a wire straight from the battery to the compressor it works fine but when i just plug it up it doesnt. is there a short in the wire? what could be the possible reasons for this? thanks
Old Jun 21, 2010 | 12:37 PM
D16SiHatch's Avatar
Default Re: a/c problems
the pressure switch will prevent the compressor from getting power if the pressure is too high or too low. check to see if you have power on one side of the switch. if so, then recover what's in the system and refill with the proper amount. if you don't have power at either wire at the pressure switch then i suspect a break in the wire or possibly a fault climate control panel.
Old Jun 21, 2010 | 01:10 PM
alright im goin to check that out tonight...im pretty sure it has the right amount of pressure. i had the compressor running when i put the freion in. thanks.
uptownx24x
Jul 24, 2011 08:07 PM
spcjenn
Aug 13, 2010 04:00 PM
spcjenn
Aug 4, 2010 11:33 AM
bigchris2000
Jul 3, 2010 08:35 PM
Magick211
Feb 23, 2003 07:00 PM
