Where is my coolant going ? ut oh..
Ok so I just changed my thermostat thinking that it was over heating because of that and it wasnt. I just checked my coolant level because it started to get pretty hot last night and I noticed it was low again . I didnt see anything leaking around the head gasket or any other signs of that . Ideas? Waterpump ?
is the actual radiator low or just the overflow resevior? if its just the tank then try replacing the rad cap. if its the radiator itself then there must be a leak elsewhere in the system. there are many other hoses that could be leaking. check the back of the block at the water pipe and all the heater hoses. worst case scenario, its leaking into the cylinders (blown headgasket)
deerman2701
18
Sep 6, 2013 01:55 PM
panchlow
May 2, 2011 05:06 PM
xpdude
28
May 3, 2010 02:33 PM
