g23 build
hey whats up people. I wanna build a g23 now.
so i know some of the things i need im goin all motor, NO nitrous and taking it to only 7,500 or 7,800rpm.
Goals are about 250whp to 260whp
my ??? is
1)does arp make rod bolts for the f23?
2)what head studs & gasket combo do i use?
3)K20A2 pistons or H22type S pistons & what compression does it yield??
4)were can i buy these factory pistons without buying them at the dealer?
5)f23 water pump with h22 gear?
i would REALLY appreciate you're help and input in all this.
my ??? is
There's a couple builds in the Prelude section that can help you out...
PM sent about the rod bolts
h22 pistons will stick out of the hole, but is really your only option if you stick with the h22 block
Those are the only one's I know definitively. Search around and you can find the answers to your other questions.
PirateMcFred is the man to see about the G23 hybrid builds.
This is his most recent G23 Thread; https://honda-tech.com/forums/all-motor-naturally-aspirated-44/g23-vtec-street-build-dyno-2781266/
There was another one a few years back that you should be able to find easy enough as well.
