Is a LS b18b1 a great setup in a eg 4dr.
Old Jun 20, 2010 | 10:22 PM
Andrew14's Avatar
Default Is a LS b18b1 a great setup in a eg 4dr.
I want to do a engine swap but im on a budget so do you think a ls in a eg 4dr is a good set up?
Old Jun 20, 2010 | 10:28 PM
92bseries's Avatar
Default Re: Is a LS b18b1 a great setup in a eg 4dr.
it has the torque, the swap is nicely priced, and the trans has longer gears so u get better gas mileage, i would give it a yes
Old Jun 20, 2010 | 10:54 PM
roycivic92's Avatar
i would get a b20 for even more torque. but a ls is a way better swap than the stock motor. either one u going to like over the sohc.
Old Jun 21, 2010 | 06:39 AM
Andrew14's Avatar
also is it true when you get the b20 the intake manifold cant fit under my hood so i have to use a ls one.
Old Jun 21, 2010 | 06:43 AM
Andrew14's Avatar
And the b20 and ls engines use the same eg mounts.
Old Jun 21, 2010 | 08:38 AM
Gunmetal_B20_Hatch's Avatar
depends upon the year model of b20
Old Jun 21, 2010 | 09:05 AM
Andrew14's Avatar
what about the b20b in the eg sedan will the b20 intake mani fit
Old Jun 21, 2010 | 09:08 AM
Civic483973's Avatar
the best thing to do would be to keep your b18 block (unless you can get the b20 block and buy a vtec head. this will be a bit more money wise and work wise though its a lot better performance
B20_EG8
May 3, 2007 01:22 PM
dynastysd
Apr 22, 2005 04:40 PM
tree
Aug 21, 2003 07:11 PM
buddy club vx
16
Nov 19, 2002 10:58 PM
