Which engine mount/bushing/bracket with DC subframe?
Searched "DC subframe", but didn't find what I was looking for. I have a DC subframe, LCAs, and rack to install in my '99 EK. Which engine mount/bushing/bracket do I use with the DC subframe?
Thanks,
Andrew
Thanks,
Andrew
For now, I will be using the factory D16. I'm assuming the DC rubber mount and EG bracket, but I would like a confirmation.
Thanks,
Andrew
Thanks,
Andrew
Yep, I am swapping the entire subframe with rack, LCAs, and strut forks. I have a K24 swap I'm piecing together and the DC subframe will give me more room in the engine bay, I can use the EKK2 mount kit, and take advantage of the quicker steering rack.
BUT, while I am getting all my parts for the swap, I would like to go ahead and install the subframe, suspension, and brake parts I have. SO, I'd like to know what I need to retain the D-series status with the DC subframe. For now
Thanks,
Andrew
Thanks,
Andrew
yea i just did this swap as well, but with a bseries motor
basically it changes everything to like a dc2/eg
so if you are using a dseries engine just use the eg Dseries rear mount. If using the bseries motor use the DC2 rear bracket. Manual mount for manual tranny of course
pm me if you have any questions
oh i have some info on my blog too if you want to check it out
http://98luder.wordpress.com/categor...n-96-00-civic/
basically nonps ek rack and subframe to dc2 rack and subframe
good luck
good luck
VougeEJ6
Suspension & Brakes
Jun 22, 2010 10:47 AM
crx(gator)
May 15, 2008 12:08 PM
MidShipCivic
Sep 30, 2007 06:50 PM
