what do i need to take an si stock?
both of us are good drivers but we havent ran eachother yet...what would be a good setup to beat this SI?
[Modified by maderfacker, 9:44 AM 9/14/2002]
it would help to know what kinda car you have.. and any preexisting modifications you have on ur car..
a bone stock gsr can take out a si.. you'd just have to be a better driver..
but if you have a LS.. basic bolt ons are a definite must.
*note* b16a's have lots of top end.. dont try to take them on the freeway..
[Modified by SonicBlueTeg, 2:46 AM 9/14/2002]
Ran my friends stock SI twice from a 10 mph roll. We were dead even through 1-2-3, but after 4th, I blew him away as if he let off the gas or something. had about 1.5 cars on him when I hit 90, thats when we let off.
I think he might beat me though if he had just intake
[Modified by 4DoorLS, 3:23 AM 9/15/2002]
Are we talking about drag or circuit racing. Because w/ equal drivers an integra(LS, GSR) would own on a circuit. A few reasons being...
Drag strip, I'm not so sure--there's too many variations that could go wrong in such a short period of time. A GSR should take an SI easily. An LS would be about even w/ an SI.
lets say that both drivers are equal in skill...
ls would take the si off the line, si will pull at top end
what you need to beat the si.... NAWS y0!!! heh
on another note, my cousin has a 94 tegra RS w/ a 96 LS motor.... he has i/h/e, chipped ecu, clutch but his car is quick.... i have no idea why, but its puzzling. his ls takes si's, gsr's, and type r's... i ran him in my b18c1 civic, and i BARELY beat him, but then again, he's a good driver.
ive taken sis in my LS... even Si's with i/h/e and such. Its all driver... i guaruntee you will take one on drag radials if you pull a 2.0.
This is the outcome MOST Civic SI vs Integra LS matches will look like when they're both Stock.
LS will get a little edge on the launch and a little bit of 1st gear. Then 2nd gear will be pretty close, but the SI will pull ahead a little by the end of 2nd gear. Then 3rd gear, the Si will pull decently on the LS and will keep going.
LS with Bolt-Ons should give the Si a much better match. Now this is when the drivers are equal. As we all know, that's almost never the case in a Street Race. The better driver should edge out...
a GS-R will blow a stock civic si away.. My friend has a 2000 si with 50k miles CAI and aftermarket clutch (he barks every gear).
I have a gs-r CAI, cam gears, type r flywheel and clutch. I also have 130k miles and he was about 5 cars behind in 3rd gear.
A GS-R will not blow away an Si. tell your friend to learn how to drive that thing, I have raced so many gs-r, and for mod for mod it is a drivers race, I have won more then I have lost, an ls for get about it
[Modified by SonicBlueTeg, 2:46 AM 9/14/2002][/QUOTE]
uh........I take SI's all day on the FREEWAY, all I have is a catback, and i'm automatic...hahaha
When I had my GS/LS I raced my girlfriends 00 Si atleast 40 times..
Me stock, and she has CAI.
Most of the time she beat me at the end of third gear for me.. thanks to her vtec.
First and Second gear for me were too close to tell. Usually I had the win in 1st and 2nd.
LS vs SI... if the LS has a good, strong motor... Just a CAI plus another bolt on (choose one: header,cat back,pulleys) would let you take an SI till mid/high 4th if you're a good driver.
I used to beat them (stock or with crappy mods) with just an AEM CAI and 14" steelies on my 4dr LS..... But that's not exactly equal... because I do have MadD SKillZ.
X2
X2
Im sorry ls are so slow, the only way one is going to beat me is on boost,are they have tons of mods
*Edit: And trapped 89mph in my Gen2 LS.
[Modified by Zero, 3:09 PM 9/16/2002]
last time at the track i saw a SI run 16.3 with what looked to be only an exaust, but i couldent tell
i ran a 15.7 with mods listed below (a little slower then my best but i was 80 degrees out)
just learn to drive, nothin to it. YEah, an intake would definatly give you an edge. Beaten a few Si's with the usual bolt ons , just gotta get the take off. ITs all in the launch.
