MI FS: 2000 Honda Civic SI (FPB)
Old Jun 20, 2010 | 07:02 PM
DX Hybridizer's Avatar
Default FS: 2000 Honda Civic SI (FPB)
CASH ONLY - FIRM PRICE - Car has Zero mechanical issues.
3400.00
2000 Honda Civic SI - Flamenco Black Pearl
171,XXX miles
Updated 7/7/10
Brand new Timing Belt
Powersteering Flush
Alt / Powersteering belts
Stock Alt and powersteering pulleys back on.
Updated 7/16/10
Stock SI Seats installed
Wideband 02 removed and stock 02 back in.
OBD2B installed. (Check engine light for O2 code, running with no cat. No big deal no other codes)
Updated 8/9/10
Stock SI Shocks and Springs installed with 60K miles on them.
Just touched up all chips spots and gave it a good wash.
Updated 8/15/10
Replaced stock injectors with a pair of low mile stock type R injectors, warm start stutter resolved.
List of items not currently stock on the car:
HID kit - OEM bulbs also available
Hytech knock off 2.5 collector header - Dented bottom primaries (Have a OEM undented manifold with all heat shields that goes with it)
Aftermarket 2.25" exhaust with Farty
Wicked tuner camber kits front and rear
After market rear lca's with poly bushings
Full Poly Bushing kit
Stainless steel brake and clutch lines
Unknown after market clutch - It's a bit harsh for my liking
Unknown lightweight flywheel
Cross drilled / slotted (ebay?) rotors with Hawk pads
Pioneer CD/MP3 deck - wiring in place for amp and sub in trunk.
K&N Drop in OE filter
Short throw shifter
Aftermarket poly engine mounts - NOT INSERTS
Civic CTR urethane lip included but not attached currently.
Unknown I assume ebay rear tie bar, and yellow sway bar
Lightweight Rear LCA's with poly bushings. (Not ebay rotting crap)
SI wheels wrapped it performance rubber tires are 195-50-15 which are -1 on oem sizing. Speedo is 2-4mph higher than actual..
14" del sol with ipike winter tires will be included if price is met.
Still has original motor and trans, both run like new.
Bad things:
All A/C is in place, missing belt. Told it needs a recharge. -- May fix this issue if I find time. Most likely not.
Car has door dings and chips and a couple scratchs in the hood and body. All have been touched up. Come see what you think. All the dents and chips came from past owners. It's seen it's share of road. I think the above pictures shows it's not a POS. I'd rate the body a 7.
Fender roll performed by previous owner. Cracking paint at the locations. Will need some work to stop from rusting.
Minor rust has started on driver side by the vtec sticker. Appears to be from a previous repair. Carfax shows car had one minor accident in 01. Damage location was driver side front.
Clean and Clear title ready for a new owner! You won't be disappointed.
Hood
Exterior Shots
Wheel as well showing plenty of tread left
Interior
Odd rust - Notice how it's not in the door well at all. Bad past body work?
Engine Bay
Old Jun 20, 2010 | 08:53 PM
RED_90TEG's Avatar
From: where i stunt SAND CANYON in Southern California
Default Re: FS: 2000 Honda Civic SI (FPB)
bump
Old Jun 20, 2010 | 09:24 PM
srt4mike's Avatar
Bump from a fellow EM1 owner.
Old Jun 21, 2010 | 04:41 AM
Thanks for the bumps! I have updated the list as I forgot some small items that are included.
Old Jun 26, 2010 | 07:04 PM
Tossed some more pictures up mainly of flaws. Car is now 100% for sale. PM if you have other angles or things you want to see.
Old Jun 29, 2010 | 06:56 PM
Bump
Old Jun 30, 2010 | 05:48 AM
PM's responded. Thanks for the interest and lets hope for a fast sale. I need driveway space!
Old Jun 30, 2010 | 07:21 PM
Bump. Timing belt, powersteering and alt belts replaced tonight so the next owner doesn't have to F with it for a LONG TIME.
Old Jul 1, 2010 | 04:43 AM
goldgreen90ef's Avatar
bump for a good deal and ef-honda too!
Old Jul 2, 2010 | 05:16 AM
Thanks!
Just put some new plugs in last night. Purchased all new belts to put on this weekend. Car should not need any required engine maintenance for another 100K miles.
Old Jul 7, 2010 | 06:08 AM
Busy weekend.
Stock OEM SI seats are back in the car with 8 way adj
Pulled the AEM TRU POWER pulley's off the alt and powersteering and put the stock ones back
New Belts for both items
new Timing belt, water pump added as I had no clue when the last owners did it.
Bump before it's the same price and has 0 aftermarket parts.
Old Aug 13, 2010 | 09:48 AM
Stock suspension will be on it next week.
Old Aug 28, 2010 | 07:20 AM
Updated pictures! VINs match. Help get this sold H-T
Old Sep 3, 2010 | 11:02 AM
finozachary's Avatar
i hope this is around when my grant gets mailed, I am forever looking for a brother for my ej8.
Old Sep 4, 2010 | 05:08 PM
Car is sold.
Old Sep 7, 2010 | 06:23 AM
Ryan111987's Avatar
you got pm
williamZ
Feb 2, 2012 03:54 PM
DX Hybridizer
Sep 4, 2010 05:10 PM
civicsiguy00
Dec 23, 2006 08:08 PM
BuCU
Jun 19, 2003 11:11 AM
