Suspension & Brakes Theory, alignment, spring rates....
Sounds coming from the front driver side wheel.
Old Jun 20, 2010 | 03:47 PM
redlinexd's Avatar
Icon6 Sounds coming from the front driver side wheel.
Okay, while I was driving my eg, I noticed that whenever I run over a bump, or those reflector things on the road, somewhere near the wheel of the front driver side makes a sound of a slinky rolling downstairs in every bump I run over. When I step on the brakes, the same side makes a HUGE squeal and when I press harder it becomes a higher pitched squeal. Then when I make a left or right turn from a stoplight, it makes that slinky noise again! Is there something wrong with the power steering and the brakes? If I intend to switch out the brake pads + rotors, which brands do you guys think is the most bang for the buck? (not trying to do brake conversions, just want to replace pads & rotors)
Old Jun 20, 2010 | 05:04 PM
redlinexd's Avatar
Default Re: Sounds coming from the front driver side wheel.
dang this sucks, i feel embarasssed when i drive it, everyone is looking at me like WTF? lmfao maybe ill upload a video of me driving it for 30 seconds.
Old Jun 22, 2010 | 11:38 AM
Duane_in_Japan's Avatar
We will wait for the video, thanks for that, but it sounds like your typical bad outer CV joint, here I would change the outer joint, in the USA, I would get a whole axle with warrantee, but lets have a listen on your video first, sounds like you need brakes too.
sfcd5
Feb 5, 2009 06:40 PM
boggey
Aug 23, 2007 10:17 AM
redGSRguy
May 22, 2006 11:01 AM
kimota
Sep 26, 2005 01:23 PM
n3v3tz
Feb 4, 2004 12:30 PM
