95 Integra project fs/ft
Old Jun 20, 2010 | 02:32 PM
atleast-3's Avatar
Default 95 Integra project fs/ft
1995 LS Integra, 95 Ls engine and trans.
Car currently isnt running, the battery is dead. Needs a re-charge. Needs a few things to make it drivable, I just dont have time to finish this car, I have a family and work to many hours. Lots of brand new parts with ZERO miles on them, some parts are used but in g/c. Would like to sell for $4000 or do a partial trade plus cash on the buyers end for a honda/acura. As for the trade, it would need to be a 5spd, have a/c, and be reliable.
Please send all offers to PM! Thanks for looking.
What needs to be finished:
-suspension needs alignment
-wire dual radiator fans to a switch or hook up relays again
-needs brake booster switched to RS model (comes w/ car)
-recharge battery
-some fresh gas
-couple misc hoses from tb to intake mani.
-e-brake needs adjustment
-needs new oil press sending unit from autometer
Chassis:
-1995 title clean
-Power steering delete, custom breather setup installed
-ABS delete, swapped to RS setup, needs brake booster installed
-A/C delete, type R a/c delete tube installed under dash
-SRS system delete
-semi engine bay wire tuck
-body has some normal dings, and a couple small spots of rust on passenger 1/4 panel
-front end is black because, I replaced the riced out fiberglass crap that used to be on it
-rear wiper delete
-I have have most all parts taken off car that will be included
-stock rocker panels included
Suspension/Wheels/Brakes:
-15x6.5 rota subzeros w/ kuhmos I believe
-advance design struts w/ ground control coilovers
-gsr upper strut bar, no name lower front tie bar
-wicked tuning front/rear camber kits
-jdm type r rear sway bar 23mm I think
-asr rear subframe brace
-pic rear lcas
-Stainless braided lines
-cross drilled sloted rotors
-all new pads dont remember which brand
-master cylinder brace
Interior:
-type r cd player
-type r passenger airbag tray
-gauge cluster not original to car/ amber bulbs
-cobra imola drivers bucket
-buddy club side mount drivers seat rail
-corbeau passenger bucket and seat slider
-sparco harness drivers side
-wicked tuning 3pod din holder
-autometer water temp, oil press, and volt gauges
-missing a couple passenger door parts I was de-ricing the interior
Engine:
-95 LS engine and trans
-Hondata s200
-type r fuel pump and injectors
-skunk2 intake manifold
-type r throttle body
-comptech intake box/filter and lower tube
-ss fuel line
-alum fuel rail w/ b&m adjustable fpr and gauge
-aem adjustable cam gears
-dc 4-1 headers
-esplir high flow cat
-no name midsection exhaust
-greddy dt rear section
-aluminum radiator with dual fan setup
-crower all motor cam and valve springs
-b-16 pistons
-n-1 type r crank pulley
-act stage1 clutch and lightweight flywheel
-wires for v-tec have been run for possible head swap
-brand new shift linkage
-skunk2 short shifter and bushings
-oddy 680 battery and summit battery holder
-msd coil and cap
-gates hoses
Pics:
Old Jun 21, 2010 | 09:12 AM
atleast-3's Avatar
Default Re: 95 Integra project fs/ft
ttt
Old Jun 21, 2010 | 11:22 AM
TheLegendRGS's Avatar
bump for you, glws wish i could i pick this up ive taken a liking to integras lately
Old Jun 21, 2010 | 08:01 PM
atleast-3's Avatar
no offers huh..
Old Jun 22, 2010 | 02:38 PM
atleast-3's Avatar
bump
Old Jun 28, 2010 | 06:50 PM
atleast-3's Avatar
bump Any trade offers?
Old Jul 4, 2010 | 09:28 AM
atleast-3's Avatar
ttt
jbell
Northeast (Sales)
Apr 28, 2011 11:58 AM
atleast-3
Dec 7, 2010 01:17 AM
atleast-3
Nov 8, 2010 04:27 PM
atleast-3
Jul 27, 2010 08:03 AM
